AFR 185
Old 02-07-2008, 09:26 PM
87WSP5.0
87WSP5.0's Avatar
Default AFR 185
I just picked up a set of used AFR 185 with comp magnum 1.6 RR for $1100. Can these valves clear the pistons with the stock camwithout notching the pistons.
[/align]
87WSP5.0 is offline
Old 02-07-2008, 09:31 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: AFR 185
that'll depend largely in part on the cam you will be running.. but if it is a cam with a great deal of lift and duration and installed straight up ..you most likely have to notch him
mjr46 is offline
Old 02-07-2008, 09:44 PM
5spd GT
5spd GT's Avatar
Default RE: AFR 185
Lift is not an issue for piston to valve clearance.
As stated though, it depends on the camshaft opening and closing events at particular points. More precise, the intake opening and exhaust closing (aka: period of overlap).
5spd GT is offline
Old 02-07-2008, 09:53 PM
mjr46
mjr46's Avatar
Default RE: AFR 185
ORIGINAL: 5spd GT
NO SHYT SHIRLOCK.... THAT's not the point I was trying to make even though the wording sounds as such
mjr46 is offline
Old 02-07-2008, 10:11 PM
5spd GT
5spd GT's Avatar
Default RE: AFR 185
Just making sure it was clear, that is all. Sorry about sounding rude...
5spd GT is offline
Old 02-07-2008, 10:17 PM
94 G STANG
94 G STANG's Avatar
Default RE: AFR 185
NO SHYT SHIRLOCK.... THAT's not the point I was trying to make even though the wording sounds as such [sm=alcoholic.gif]
lol that was a good one!
94 G STANG is offline
Old 02-07-2008, 10:18 PM
mjr46
mjr46's Avatar
Default RE: AFR 185
No problem I'm not mad......I know that lift is not a determining factor of ptv.. more so I was trying to emphasize that I have seen afr 185's on a stock bottom end and cam work without notching but once performance cams enter into the picture without knowing all the specs at what degree in the cycle the valves are timed to open.....more so I should of said in my first post...performance cam + 2.02 valved head = clay the pistons and check for interference which often occurs on the corners of the valve reliefs... or we could just avoid the whole issue and use a canted valved head like a twisted wedge head.....anyway sorry for being so defensive 5spd gt
mjr46 is offline
Old 02-07-2008, 10:29 PM
87WSP5.0
87WSP5.0's Avatar
Default RE: AFR 185
I will be using the stock cam.
[/align]
87WSP5.0 is offline
Old 02-07-2008, 10:34 PM
mjr46
mjr46's Avatar
Default RE: AFR 185
you most likely will be fine.. but either way it's always a good idea to clay the piston and check your clearance.....look at it this way....would you want to ruin a expensive set of heads from the get go??
mjr46 is offline
Old 02-07-2008, 10:43 PM
87WSP5.0
87WSP5.0's Avatar
Default RE: AFR 185
I think the last time I used clay I was about 7, but I will try it. Also who sells cheap valve covers that clears roller rockers?
[/align]
87WSP5.0 is offline
Quick Reply: AFR 185
