Rear end question
Old 02-08-2008, 09:46 AM
94RedDevil
94RedDevil's Avatar
Default Rear end question
I'm not pushing a ton of power but I'm trying to build up the suspension and rear end so I can drop a 351W in there and play with that. What I was planning was an Auburn locker b/c my awesome ford Trac-lok is only spinning one tire now, and some Moser 31-spline axles. Later I will put some drag radials on when i get money. Anything else I need? I already have 3.73 gears. I would appreciate any advice that you could give me. I'm a first timer. Thanks.
94RedDevil is offline
Old 02-08-2008, 10:33 AM
bighungrymatt
bighungrymatt's Avatar
Default RE: Rear end question
what kind of power goals are you wanting to get too once you build your 351w?
bighungrymatt is offline
Old 02-08-2008, 09:30 PM
95 BLOWN GT
95 BLOWN GT's Avatar
ORIGINAL: bighungrymatt
+1 i have an eaton posi unit and it works great . how much h.p are you looking at?
95 BLOWN GT is offline
Old 02-08-2008, 10:19 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
yeah get some subframes
mjr46 is offline
Old 02-08-2008, 10:32 PM
jman511115
jman511115's Avatar
http://www.buyfordracing.com/shop/pr...roducts_id=481
http://www.buyfordracing.com/shop/pr...roducts_id=463
http://www.americanmuscle.com/royal-...-gear-oil.html
Do it right the first time.
Edit: Assuming you have an 8.8.
Are you looking at this?
http://www.4wheelerssupply.com/catal...ducts_id/71249
jman511115 is offline
Old 02-09-2008, 12:52 AM
Maxwelhse
Maxwelhse's Avatar
Scratch the Royal Purple and that weight...
http://www.auburngear.com/aftermarket/faq/
2.)What kind of oil should be used with an Auburn differential?
It is important when installing Auburn differentials that a high quality, non-synthetic 80w90 GL-5 oil, treated with GM or Ford limited-slip additive (also known as friction modifier) be used. Three ounces of additive will treat one quart of oil.
Ford friction modifier:
http://store.summitracing.com/partde...p;autoview=sku
And get a set of these:
http://www.jegs.com/webapp/wcs/store...10002_15068_-1
Maxwelhse is offline
Old 02-09-2008, 05:46 AM
94RedDevil
94RedDevil's Avatar
Sorry I did not get back to you guys yesterday. I want to stroke the 351 to a 427 and later down the line, add some twin turbos (I wont be able to aford it all at once). I want somewhere around 700-800 rwhp
GimpyHSHS
08-29-2015 06:30 PM
91StangOwner
08-20-2015 11:34 PM
Black_GT_02
08-20-2015 01:26 PM
ding56
08-14-2015 02:40 AM
92 5.0stang
08-13-2015 06:46 AM
Quick Reply: Rear end question
