Spun Flywheel.... - Page 2 - MustangForums.com
Sponsored by:
Sponsored by:
Old 02-08-2008, 03:19 PM   #11
bighungrymatt
Default RE: Spun Flywheel....
bighungrymatt is offline   Reply With Quote
Old 02-08-2008, 05:02 PM   #12
NotFingflyinnow
Thanks for the Link, I think that will be all I need. If I have any problems, youll see me posting questions [:'(]
NotFingflyinnow is offline   Reply With Quote
Old 02-08-2008, 05:43 PM   #13
aode08
The stock starter is made of softer metal than the flywheel. You should be ok.
Typically, the starter will grind its teeth off
aode08 is offline   Reply With Quote
Old 02-08-2008, 05:51 PM   #14
aode08
If it is bad, put the car on jackstands, remove the torque conter to flywheel nuts(13 or 14mm)((4 of them)), turning the crankshaft clockwise to get to each one.
Remove the dipstick tube, fluid will come from tranny. Put jack Under Tranny Pan More Toward the front of the pan, unbolt the tranny to engine bolts (16mm), unbolt the two tranny rear mount bolts and slide em out.
Move tranny back, take the flywheel off and install new. Use new flywheel bolts and blue loc-tite.
Removing the old one will require a short pipe to add the extra strength to your hands.
Old 02-08-2008, 09:16 PM   #15
Jfsram
Jfsram's Avatar
Quote:
ORIGINAL: FivePointOhh
best advice, jack up the car, unbolt the drive shaft and drop the tranny out and actually look if you really think its the flywheel. shouldnt take more than an hour.
Drop the starter before you go yanking out the entire transmission.
Jfsram is offline   Reply With Quote
Old 02-08-2008, 10:37 PM   #16
NotFingflyinnow
In ya'lls opinion what are the chances my stock starter grinded teeth off instead of breaking enough teeth off my flywheel to cause this problem?
Old 02-09-2008, 10:53 PM   #17
NotFingflyinnow
anyone have an opinion about the starter teeth?
Old 02-09-2008, 11:13 PM   #18
AdderMk2
Banned
chances are better that the teeth are gone on the starter..
you have to unbolt the starter to remove the bellhousing.... so you might as well take it out first and go from there
AdderMk2 is offline   Reply With Quote
cobra vs heavy hitter vette's ctgreddy Street/Strip 11 09-20-2015 08:35 PM
what are the best phone apps for 0-60 MonsterBilly Classic Mustangs (Tech) 4 09-20-2015 06:56 AM
timing issue 1987gt40ttopt 5.0L (1979-1995) Mustang 12 08-28-2015 10:49 PM
Clutch cable issues ponyride00 4.6L (1996-2004 Modular) Mustang 0 08-12-2015 01:57 PM
Is this a 28 oz flywheel? mardyn 5.0L (1979-1995) Mustang 5 04-01-2004 03:10 PM
flywheel, spun
