94GT 5 Speed in a Fox
Old 02-09-2008, 10:11 AM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Default 94GT 5 Speed in a Fox
I know the tailshaft is longer than a fox T5 (7.18in)but if the 94 (7.85)driveshaft was used do you guys think I would be able to use it? Or are the driveshafts the same length on both Fox's and SN's?
projectresto83 is offline
Old 02-09-2008, 10:43 AM
AdderMk2
Banned
AdderMk2's Avatar
Default RE: 94GT 5 Speed in a Fox
fox and SN use the same driveshaft. The tailshaft is NOT longer... the INPUT shaft is longer. You can use a SN trans if you use the SN bell housing... but you might need to modify your crossmember to fit propery.
or you could justswap the input shaft from a fox tranny, into your SN tranny, and use a fox bellhousing.
either way will work
AdderMk2 is offline
Old 02-09-2008, 06:48 PM
projectresto83
M.A.D. Motorsports
Thanks, modifying the crossmember is no big deal. Is there any thing else with the 94 bell that is different from a fox's?
Old 02-09-2008, 09:00 PM
AdderMk2
Banned
AdderMk2's Avatar
its 11/16" deeper
AdderMk2 is offline
Old 02-09-2008, 09:27 PM
projectresto83
M.A.D. Motorsports
Which is the reason for the longer input shaft.But other than that they are the same? Release fork's are the same? Throw out bearings? Clutch cable length (adjustable cable should work if not, right)?
Old 02-09-2008, 09:50 PM
AdderMk2
Banned
AdderMk2's Avatar
AFAIK thats it!
AdderMk2 is offline
Old 02-09-2008, 10:57 PM
94Yellow50
94Yellow50's Avatar
the clutch fork is different between a sn95 car and a fox...not sure if you could use either or ..but they are shaped a little different n ones longer...if i remember right the sn clutchfork is longer
94Yellow50 is offline
Old 02-10-2008, 08:08 AM
projectresto83
M.A.D. Motorsports
Ok, thanks guys. I guess I will have to sit and play and experiment with the 2 parts and see what works and what doesn't.
UrS4
10-03-2015 06:23 AM
BeatnikFink
10-01-2015 08:00 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
RCS02v6
09-29-2015 01:46 PM
Quick Reply: 94GT 5 Speed in a Fox
