5.0 holding back under load - MustangForums.com
Old 02-09-2008, 08:51 PM   #1
red90GT
Default 5.0 holding back under load
90 GT..although it is running great after a good seafoaming..the engine feels like it holds back in 3rd gear about 2400rpm unless i give it more throttle. 4th gear same thing. now it still has stock headers and stock H with all cats. 180000 on the clock and the cats are original. could this be where the hold back is from? if i bought shortys and a catted H pipe could this solve problem? all sensors have been changed and codes are all clear. maf cleaned and tps set at .98. new plugs everything like i said the motor doesnt hesitiate at all it just seems that under load light throttle it holds back. thanks
red90GT is offline   Reply With Quote
Old 02-09-2008, 08:53 PM   #2
notchbackmatt87
Default RE: 5.0 holding back under load
ever do a tune up. plugs cap rotor, wires? fuel filter? air filter?
notchbackmatt87 is offline   Reply With Quote
Old 02-09-2008, 08:55 PM   #3
red90GT
yes. although i am using the autolite platinum plugs. CAI bbk month old. msd 8.5mm wires with cap and rotor. blaster coil
Old 02-09-2008, 08:56 PM   #4
notchbackmatt87
could possibly be a clogged cat or partically clogged cat.
Old 02-09-2008, 08:58 PM   #5
red90GT
thanks. i never ran into an experience cat related. it doesnt smell like anything or set off the SES so i didn't know. thanks for your fast replys man..
Old 02-09-2008, 10:09 PM   #6
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
loosen the exhaust and run it like that and see if the lack of power clears up.. or pull out the o/2's and run it like that..and yes the car will still run without the o2's in...your just doing it for diagnostic purpose so it won't harm it for the short time up the road and back you do it for
mjr46 is offline   Reply With Quote
Sputtering low RPM when engine warms ShaneB26154 4.6L (1996-2004 Modular) Mustang 34 05-15-2016 09:30 AM
EFI to CARB conversion problem, running like a PIG..vacuum problem? YoungStangsMan 5.0L (1979-1995) Mustang 15 09-05-2015 07:01 PM
Did a few mods this summer... drfister 2005-2014 Mustangs 9 09-04-2015 07:47 AM
Max RWHP on Stock 5.0 Engine? 05slpGT The New S550 2015-2017 Mustang 4 08-12-2015 02:32 PM
Need Help Diagnosing Have Codes (Confused) djbigskrilla 2005-2014 Mustangs 13 08-11-2015 12:59 PM
1993, 50, back, holds, mustang
