Underdrive pulley Rubbing
My 94 has 160K miles. I just put on some underdrive pulleys. The water pump pulley is rubbing the the harmonic balancer. I ground the pulley down so it would clear. After about 5 mins of driveing it started rub again. Im thinking the Harmonic balancer is coming apart. What do you guys think? Anyone had this?? Thanks
RE: Underdrive pulley Rubbing
check to see if it wobbles!! never had a prob like that before..you shouldn't have to modify the pullies at all for install....so pulley rubs not the belt right??
ccdguy
09-19-2015 05:20 PM
