header fitment
header fitment
i was in stalling my equal length headers and i have everything almost ready to go but there doesnt seem to be enough room, the passenger side is resting on the inner fender wall and the a/c line too (i think)and the drivers side is resting on the steering shaft, how do i get around this
RE: header fitment
either loosen the motor mounts and jack the motor up a little but If I remember right....I may have removed my accessories on the fromt along with the brackets and pushed them in that way
RE: header fitment
hmmmmm ......you may have to use a tourch to heat the part touching and use a ball pean hammer and tap in the portion hittin...I may of done that to mine but it's been a while since the install so I don't remember and each manufactorers design varies..so some hit others don't[&:]
RE: header fitment
ok ill look into next time i get a chance to go up to the garage im working on my car in, how did you run your dipstick tube i have it ran inbetween two of the primarys but it seems like itll rattle when i the cars running
