aluminum radiator question
i found a guy local selling a C&R custom alumin rad ( dont know what year his stang is ) measures 16" high x 26" wide does anyone know off hand will it fit in my 89gt its wayy too cold to go outside and measure[&:]
RE: aluminum radiator question
biggest you can go(maybe just a little bit bigger if you need...) W-29.25" H-19.00" Thickness-3.25"(thats in consideration you have the stock mechanical fan...if electric you can go thicker for a three core but trust me you dont need it)
i have a stock fan and shorud, but am putting on a electric i just need a new radiator because when the guy i got the car from took the motor out he let it down ontop of the radiator and its kinda like V'ed lol and i figured this guys got this C&R for a 100 so id pick it up.
sounds like a deal. max height with the rubber inserts below and no mods to the stock mounting is 19" you can go slightly wider than 29.25 but not by much, maybe another half inch total. stock fan and shroud, 3.25 is as deep as you can go so check the thickness out, how many core is it? if its 2 it shouldnt be any bigger than 3.25
ok since this radiator is 16 inches high and 26 wide will i have to make any modifications? i need some help because if i got to make drastic mods for it it may not be worth it [:'(]
Luke9222
10-22-2015 11:55 PM
