idle
Old 02-12-2008, 11:20 AM
86whitepony
86whitepony's Avatar
Default idle
hey guys, i was just wondering if everybody could give me thier personal two cents on how to adjust idle, im having concerns withthe stang and it's a lil high at 1200 rpm and was seeing if i could get some info on how to lower it down, and it's always good to know how to doit anyways imo.
86whitepony is offline
Old 02-12-2008, 11:44 AM
86GreenMachine
86GreenMachine's Avatar
Default RE: idle
1. Clean TB with carb cleaner and nylon brush (toothbrush size). Engine off, fully open TB blade and spray/brush TB until all gunk and oil residue is cleaned.
2. Allow to dry, or close TB blade and start engine until it clears all carb cleaner fumes/liquid.
3. Let engine idle...if it doesn't, increase idle speed via TB stop screw until engine stays idling on its own.
4. Disconnect IAC valve, if engine dies repeat 3 with IAC disconnected.
5. Set idle speed to the lowest setting possible between 650-850 rpms with IAC disconnected. It is key to use the lowest possible to prevent idle surge, rolling, etc once the IAC is connected as follows.
6. Turn engine off, and reconnect IAC
7. With Ign On Eng Off, check TPS voltage output....if it's between .8vdc - 1.0vdc, it's OK. This voltage check should be done between the Green and Black wires at the TPS side connector as shown in the pic below....(-) terminal of the DVOM on the Black wire and (+) terminal on the Green wire.
[align=center][/align]
8. Disconnect battery (-) for 3-4 minutes.
9. Reconnect battery, start engine, allow it to idle for 2-4 minutes to confirm setup,
10. If idle speed falls too low or stalls, increase idle speed via the TB set screw a little at a time.
11. Turn engine off for 20 seconds, re-start engine and repeat 9 - 11 if required.
12. Reconfirm TPS output is within the .8vdc - 1.0vdc range.......you're done!...
..no need to reset ECM KAM (reset computer) b/c the TPS minimum value used for idle control, is automatically reset by the EEC-IV every time the ign is cycled on-off for 20 seconds-on, and as explained in the next post
13. Allow a 10-20 minute "relearning" period under normal driving conditions (drive cycle).....now you're done.
86GreenMachine is offline
Old 02-12-2008, 11:45 AM
nseoi
nseoi's Avatar
Default RE: idle
there is a screw right under the throttle body. with the engine running, get in there and tighten/loosen it and you will notice it go up or down. have a buddy inside telling u what rpm it is at while you do it. mine is loose enough to do by hand, you might need a socket wrench/screw driver if its too tight tho
nseoi is offline
Old 02-12-2008, 01:20 PM
94Yellow50
94Yellow50's Avatar
Default RE: idle
dont use carb cleaner it will mess up the coating on the inside ..it says clearly on the throttle body..get electronic safe throttle body cleaner instead...
94Yellow50 is offline
4cylinderplus2
10-09-2020 07:45 PM
TCStangerv6
10-11-2015 05:57 PM
svfetter
10-05-2015 11:39 AM
MacSerio
09-27-2015 01:05 PM
Scottyboy187
SVT Forums
09-13-2015 10:23 PM
Quick Reply: idle
