problem with oil light.
ok i already check my oil and it is full. when i start my car my oil light stays on until i wiggle whe lock cylinder . then all the lights light up (oil,fuel,low coolant,and washer fulid.)and go out.need help think its my lock cylinder
RE: problem with oil light.
you're probably right. take the cover off the steering column and try pushing all the connectors in all the way...
i'm not sure what year you have, but on mine there are two phillips screws. you need a pretty long thin screwdriver to get to them.. then it should just come off.
ORIGINAL: cheetha94607
zanemoseley
09-06-2015 12:58 PM
