f303 with stock pistons?
Old 02-14-2008, 01:21 PM
blk89lx
blk89lx's Avatar
Default f303 with stock pistons?
f303 cam with stock shortblock do i have to cut the pistons for clearance?
blk89lx is offline
Old 02-14-2008, 07:26 PM
FLcracker9
FLcracker9's Avatar
Default RE: f303 with stock pistons?
What year?. I'm not an expert, but I believe the 86s had flat tops that could be an issue. 87 and later should be fine as long as the cam is indexed correctly. But as you've seen on here before, the only way to be 100% positive is to check piston to valve clearance.
FLcracker9 is offline
Old 02-14-2008, 08:38 PM
Joel5.0
Joel5.0's Avatar
What heads..... ported E7's, GT40's, GT40p's?....... very unlikely.... you should check for PtV anyway and degree that F-cam though.... + upgrade the valve train.
Joel5.0 is offline
Old 02-14-2008, 08:40 PM
blk89lx
blk89lx's Avatar
its a 91 with edelbrock performer rpm heads?
blk89lx is offline
Old 02-14-2008, 11:19 PM
Tberg725
Tberg725's Avatar
Just check PTV, better to be safe then sorry.
Tberg725 is offline
Old 02-14-2008, 11:23 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
what size valves ??
mjr46 is offline
Old 02-15-2008, 12:07 AM
5spd GT
5spd GT's Avatar
The precision of the camshaft accuracy is not always spot-on. A degreed camshaft is a good place to start to see where the camshaft stands in comparison to where it should be.
Valve diameter is a factor as well.
5spd GT is offline
Old 02-15-2008, 11:00 AM
blk89lx
blk89lx's Avatar
ahh its the 1.90 not the 2.02
blk89lx is offline
Old 02-15-2008, 03:15 PM
redpony88
redpony88's Avatar
then it should be fine, i ran the 2.02 valves on my stock bottom end with the f cam
redpony88 is offline
uberstang1
12-07-2017 07:10 AM
poke68
12-15-2015 06:25 PM
uberstang1
09-20-2015 06:42 PM
degner122
09-16-2015 07:09 AM
EASTIDEE123
09-14-2015 03:52 PM
Quick Reply: f303 with stock pistons?
