New heads..what else?
RE: New heads..what else?
most likely this much http://cgi.ebay.com/ebaymotors/Ford-...spagenameZWDVW
Just contact whoever you bought them from that you're having clearance issues or that they didn't send the right ones and get rid of them. These guys on here know their sh**, trust me, they've helped me out more times than I can remember, don't take offense to the advice that they're giving you, they're only trying to help you get out of a bad situation.
I didnt purchase the heads my parents got them for me for a graduation gift, my dad knew i was looking at heads so he was looking for the cheapest aluminum ones...I didnt buy them or pick them out..i was looking at some patriots or the gt40's from blue oval industries. But i told the guy that i have no use for them and im getting my money back. but i just turned 18 a few months so yes i may be ignorant, but do NOT call me retarded.
And by teling me to throw them away, you really helped me figure out what to do..
ORIGINAL: cougarfan088
yes i sent them back today and got my money back, i told my dad that they sent me the heads for a chevy and that he ran out of sbf ones so hes getting the money back, i told him to just give me the money and ill take care of it.
Cougar - Don't let peoples rude attitudes get to you. You did the right thing. Work with what you have, and have fun.
When you go to do a H/I swap or H/C/I swap, maybe this checklist will help you. Just look to see what you need and do not need:
'87-'95 Heads, Cam, Intake Install Help
Checklist and Suggested Parts:
Parts are specific for 87-93 although most parts are the same for 94/95.
Head Gaskets - ROL-HG32841HR (.039) or ROL-HG32841HT (.045)
Lower Intake Gasket β FEL-MS93334 (stock) or FEL1250S
Upper to Lower Intake Gasket β Depends on Intake Used.
Valve Cover Gaskets* - FMS-M-6584-A50 (OEM)
Thermostat Gasket - FEL-35440
Timing Cover/Front Seal/Water Pump/Oil Pan U Gasket Kit - FEL-TCS45449
Water Pump Gasket - FEL-35211 (Plate to Block), FEL-35380 (Pump to Plate)
Head Bolts - FEL-ES72155 (stock), ARP-154-3601 (7/16β, recommended)
Header/Manifold Gaskets β FEL-1415
EGR Valve Gasket* - EDL-3830 (65-70mm TB/EGR/Plate to Valve Gasket)
Throttle Body Gasket - Same as above.
Intake Air Bypass Valve Gasket* - Same as above.
Hardened Pushrods
Timing Chain/Gear - FMS-M-6268-A302 or RollMaster - CS3071
Fuel Injectors - Stock 19lb injectors, 24lb (Cobra), 30lb injectors common
Mass Air Flow Sensor Calibrated for Injector
Fuel Pump (Stock is 88 or 95lph β Upgrade to 155/190/255lph)
*Optional
There are many different brands of products that you could use above instead of the ones outlined.
Tools:
ΒΌβ-15/16β Shallow and Deep Well Sockets and Wrenches
Combination of Extensions
Break Over Bar
Torque Wrench
Harmonic Balancer Puller
Gear Puller* (optional for stubborn timing chain)
Moroso Oil Pump Primer* - MOR-62210
A/C and Fuel Line Disconnect Tools*
Allen Wrenches*
Adjustable Wrench
Flathead and Phillips Screwdriver
Cam Degree Kit*
LocTite
Ultra Black RTV
Antiseize
Thread Sealer for Lower Head Bolts and Coolant Sensors
Assembly Lube or Oil for cam/lifters
Two Oil Changes and Filters
Ford Thermactor Plugs* (2 extra plugs if no smog equipment)
Gasket Scraper
Brake Cleaner
Degreaser*
Ziploc Bags*
Masking Tape*
Marker*
*Optional
Check out www.rockauto.com for any more parts/tools you may need.
Torque Specs:
Camshaft Thrust Plate Bolts: 108-144 in. lbs (6-9 ft. lbs)
Camshaft Sprocket Bolt: 40-45 ft. lbs
Timing Cover Bolts: 12-18 ft. lbs
Water Pump Bolts: 15-21 ft. lbs
Water Pump Pulley Bolts: 15-21 ft. lbs
Harmonic Balancer: 70-90 ft. lbs
Crankshaft Pulley Bolts: 35-50 ft. lbs
Cylinder Head Bolts: 70 ft. lbs for Aluminum Heads*
Rocker Studs: 60 ft. lbs
Exhaust Manifold/Header Bolts: 26-32 ft. lbs
Valve Cover Bolts: 3-5 ft. lbs
Rocker Arm Fulcrum Bolts (Pedestal Mounted): 18-25 ft. lbs
Lower Intake Manifold Bolts: 23-25 ft. lbs**
Thermostat Housing: 12-18 ft. lbs
Upper Intake Bolts: 10-12 ft. lbs
*Read head bolt instructions and torque in stages
**Retorque in tightening sequence after a couple heat cycles
Extra Torque Specs:
Main Bearing Caps: 60-70 ft. lbs
Connecting Rod Bolts: 25 ft. lbs
Oil Pan Bolts: 9-11 ft. lbs/18 ft. lbs at timing cover and rear main side.
Flywheel Bolts: 75-85 ft. lbs
Loc-Tite Camshaft Sprocket Bolt and Thrust Washer Bolts.
5/16β Bolt Head β Intake Air Bypass Valve, Fuel Rail
3/8β Bolt Head β Timing Cover Bottom
7/16β Bolt Head β Water Pump Pulley, Valve Cover, Header/Manifold
1/2β Bolt Head β Lower/Upper Intake, Head, Throttle Body, T-Stat, Timing Cover
9/16β Bolt Head β A/C Bracket, Alternator
5/8β Bolt Head β Long Alternator, Water Pump, Oil Pan
I do not like the word "retard" by the way.
Hardened Pushrods
*Optional
Tools:
Break Over Bar
Torque Wrench
Allen Wrenches*
Adjustable Wrench
Cam Degree Kit*
LocTite
Ultra Black RTV
Antiseize
Gasket Scraper
Brake Cleaner
Degreaser*
Ziploc Bags*
Masking Tape*
Marker*
*Optional
Torque Specs:
Extra Torque Specs:
