alternator questions
the problem - above 2000 rpm i get a turbo whine from under the hood, i dont have turbo and the noise drives me crazy, its like a vacumm cleaner sound
traced the sound, pretty sure its the alternator, probably bearings...
1) how difficult is it to replace the bearings on the alternator
if i replace the alternator how many amps do i need to run smaller pullies and do i need to do a 3g conv. to avoid idle issues
RE: alternator questions
don'tbother w/ the smaller pullies it's not worth the hassles of charging probs
pull the alt, go to autozone or kragens or whoever does an alt test for free, and see if it whines when they test it
do it in the parking lot so your good to go, if it tests bad just get a new one, they are lifetime warrantied
if it doesn't sqeak...check the smog pump
ORIGINAL: mjr46
you don't replace the bearings in the alt...you go down to the local parts store and get a new alt if it's the cause
okay
shouldnt be the smog pump just replaced it...(i'll be pissed if it is)
are the bolt in replacements that plug into the o.e set up with higher alt put outs, i mean my voltometer in the car reads fine. but i do have a stereo system with an amp and whetev, is it worth the upgrade
thanks for the help
thanks for the help
replaced the alternator, noise still happening, how difficult is it to replace the tensioner pully, belts a little glazzed so it might be slipping, its a new belt, got it in nov. when i replaced the smog pump
treesloth
09-28-2015 07:03 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
