Pilot Bearing During Clutch Swap
Old 02-16-2008, 05:19 PM
sowaxeman
Retired Moderator
sowaxeman's Avatar
Default Pilot Bearing During Clutch Swap
I am in the middle of swapping out my clutch for a new OEM spec clutch on my '85 GT vert. The car is a cruiser only so I didn't opt to go to a 10.5 this time around. I have the flywheel out to get it resurfaced and was wondering do I need to replace the pilot bearing too (thats the bearing at the end of the crankshaft correct [&:]). The car only has 40k on the clock so was thinking it should be fine.
If you think I should replace it, what is the trick to getting the old one out?
sowaxeman is offline
Old 02-16-2008, 07:08 PM
bighungrymatt
bighungrymatt's Avatar
Default RE: Pilot Bearing During Clutch Swap
It wouldnt hurt to change it out while you are down there, when I did mine I rented a bearing puller from the auto parts store.
bighungrymatt is offline
Old 02-16-2008, 07:15 PM
primetime5.0
primetime5.0's Avatar
its cheap insurance do it now, so you dont have to worry about it later
primetime5.0 is offline
Old 02-16-2008, 07:29 PM
uedlose
uedlose's Avatar
I would not put a clutch in without changing it.
uedlose is offline
Old 02-16-2008, 07:30 PM
AdderMk2
Banned
AdderMk2's Avatar
its either $10 now, and change it.... or hours of down time and possible damage if it goes bad after you are done!
AdderMk2 is offline
Old 02-16-2008, 07:41 PM
bouchermb
bouchermb's Avatar
I'd absolutely do it while you have the trans down and are replacing the clutch anyway.
No reason not to.
bouchermb is offline
Old 02-16-2008, 08:42 PM
sowaxeman
Retired Moderator
sowaxeman's Avatar
Thanks for the advice. I will change it and borrow a puller from one of my club members.
GimpyHSHS
19
12-19-2023 01:12 PM
Thunderball
15
11-22-2015 11:49 PM
Matt's 95 Stang
10-05-2015 07:16 AM
junior04
09-28-2015 10:53 AM
MacSerio
09-27-2015 01:05 PM
Quick Reply: Pilot Bearing During Clutch Swap
