Stock fuel pump
Old 02-17-2008, 09:54 PM
87WSP5.0
87WSP5.0's Avatar
Default Stock fuel pump
How much power is the stock pump good to? I just installed AFR 185s. Once I get over 4,000 rpms it feels like i'm running out of fuel and then its power goes flat. That was with fuel pressure at 45psi with 19# (I was told they were good to a little over 300HP)injectors, I turned the pressure up to 60psi and it helped a little. Crusing at 70 the power is good as long as you don't get into the throttle to much, when you do it builds power but quickly gets sluggish. Cam is stock and I am getting 24# injectors.
[/align]
87WSP5.0 is offline
Old 02-17-2008, 09:58 PM
LTnone
LTnone's Avatar
Default RE: Stock fuel pump
Stock pumps are 88lph I think. My stocker was a 95lph unit, don't know why. Either way, it would only benefit you to get the thing replaced
LTnone is offline
Old 02-17-2008, 10:03 PM
86 5.0L
86 5.0L's Avatar
http://www.jdsperformance.com/index....amp;inmake=136
get the 255lph
86 5.0L is offline
Old 02-17-2008, 10:35 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
I really don't think injectors may be your whole prob..more so a mismatch of components ...a stock cam really isn't going to be help those 185's reach their full potential amd 165's would of been a better choice for you.......either way upgrading to 24's and a bigger pump will be a benificial upgrade for all the future mods you may have planned
mjr46 is offline
Old 02-18-2008, 07:18 AM
ewgoetz
ewgoetz's Avatar
Change the cam first.
ewgoetz is offline
Old 02-18-2008, 08:39 AM
aode08
aode08's Avatar
ORIGINAL: 87WSP5.0
[/align]
are you using 1.7 Roller Rockers?
When you replaced the heads, that beat up rusted ground strap on the driver rear head, where is that now, and the other ground strap that is orange?
What is your timing set at and what kind of exhaust sytem ae your running?
What kind of intake manifold?
aode08 is offline
Old 02-18-2008, 05:39 PM
87WSP5.0
87WSP5.0's Avatar
I just put 24# injectors on and it helped a little. Then I started raising the fuel pressure again and it helped a little more. Intake is a Typhoon and full exhaust with shorty headers. The timing could be off a little because I did it by ear (my friend said he had a timing light but did not). Ground straps are now on the block.
[/align]
87WSP5.0 is offline
Old 02-18-2008, 05:50 PM
mjr46
mjr46's Avatar
you need to pull the spout and set timing with a light... no other way to do it
mjr46 is offline
Old 02-18-2008, 06:36 PM
5spd GT
5spd GT's Avatar
The camshaft is what is giving you the "signing off" feeling because that is what it is doing.
Stock fuel pump size is 88lph for the earlier foxes, and 95 lph for the later fuel pumps.
5spd GT is offline
Old 02-18-2008, 11:58 PM
gothand
gothand's Avatar
According to the Ford Racing parts catalog ...
... for naturally aspirated engines
Safe "Horsepower Capacity" @ 40 psi with 12V
88 lph = 250 hp
110 lph = 315 hp
155 lph = 440 hp
190 lph = 540 hp
255 lph = 700 hp
Injectors @ 90% duty cycle
19# = 275 hp
24# = 350 hp
30# = 425 hp
36# = 520 hp
No need to go so big that you could never justify using it (i.e. 255 lph pump for a naturally aspirated 5.0L motor).
Good luck!
Jeff
gothand is offline
Quick Reply: Stock fuel pump
