I need to fabricate a clutch cable
Old 02-18-2008, 09:01 AM
outrunstang
outrunstang's Avatar
Default I need to fabricate a clutch cable
I have a 91 Mustang. I have a competition clutch in it. It takes a lot of pressure to get the clutch engaged. That said the cable busted. It turns out it has been replaced before. (This mustang is new to me) The cable is freyed at the top and whatever was holding it to the clutch pedal busted. I went to Autozone and bought the cable and it looks the same except for the end fittings. The one on my mustang down near the transmission is a threaded piece with a nut on it. That has to be fabricated I am guessing.
The new one will not work. So, I want to keep the cable that is on their but want to put some sort of fitting that will allow me to put it back into the clutch pedal. Where it hooks in at there are 3 maybe 4 slots that you can put it in. But also I don't even know how it is suppose to stay in there. Anyone with info please let me know.
Thanks, Jason
outrunstang is offline
Old 02-18-2008, 09:12 AM
nseoi
nseoi's Avatar
Default RE: I need to fabricate a clutch cable
the one with the thread is just an ajustable cable. get a BBK cable if you want something heavy duty. the stock cable is not ajustable and is skinnier
nseoi is offline
Old 02-18-2008, 09:14 AM
nseoi
nseoi's Avatar
this steeda one is good and cheap
http://www.latemodelrestoration.com/...1&comp=LRS
nseoi is offline
Old 02-18-2008, 09:18 AM
onesickstang01
onesickstang01's Avatar
yea i have a bbk adjustable, stage 5 centerforce clutch and this cable has had no problems holding up. id reccomend it to anyone. steeda is a very reliable one too from what ive heard but i havent used it so i cant speak from experience
onesickstang01 is offline
Old 02-18-2008, 09:21 AM
CantStopTheFox...
CantStopTheFox...'s Avatar
The cable that you had was an after-market adjustable cable...that is why the end was threaded...If you have 3 or 4 slots under the dash to connect the cable, then you prob have an after-market clutch quadrant...(I believe the stock only has one way to connect it)
For thenew one, the cable should have no problem hooking under the dash, but it may be too long/short at the tranny...You can solve that by trying each hook under the dash.
If that still does not give you the proper tension, then you can go with either another adjustable cable or a firewall adjuster. As far as fabricating the old one to connect under the dash....I do not think that is a good idea
CantStopTheFox... is offline
Old 02-18-2008, 11:00 AM
maiello2169
maiello2169's Avatar
I have a Ram stage two clutch and my cable busted too. Just go with the ford racing one...its working out fine for me, and is about twice the thickness of the aftermarket one that busted.
maiello2169 is offline
Old 02-18-2008, 11:25 AM
86 5.0L
86 5.0L's Avatar
ORIGINAL: nseoi
wrong, the OEM cable is the thickest AND strongest cable that is available, all aftermarket cables are weaker
We have done a lot of research on clutch cables, buying and testing almost every different cable on the market we could find. We have found after all this investigation, that the OEM Ford Clutch Cables are the best quality cables available. They have a multi-material, layered construction that provides better heat, friction and collapsibility protection than all the aftermarket cables we dissected. With that in mind, we have begun selling all year ranges of factory cables, for those customers that demand a cable that will last.
http://www.maximummotorsports.com/
86 5.0L is offline
Old 02-18-2008, 01:09 PM
silver91gt
silver91gt's Avatar
my grannatelli adjustable cable has held up fine for years with a centerforce df and a spec stage 3.
silver91gt is offline
Old 02-19-2008, 03:45 PM
Tberg725
Tberg725's Avatar
My aftermarker cable broke in the same spot I went to murrays and bought the 20$ stock replacement and its holding up fine. + I got a lifetime warrenty
Tberg725 is offline
Thunderball
15
11-22-2015 11:49 PM
kevsgt
10-09-2015 10:12 PM
breaking
10-02-2015 01:27 PM
Explosive
10-02-2015 07:45 AM
junior04
09-28-2015 10:53 AM
Quick Reply: I need to fabricate a clutch cable
