Different Surging Idle Fix....
Old 02-18-2008, 11:40 AM
CantStopTheFox...
CantStopTheFox...'s Avatar
Default Different Surging Idle Fix....
In my searches, I found a different method to fix the idle that is not as popular as the traditional methods:
"Open up the divider between the ports on the IAC with a dremel"
Anyone tried it??
CantStopTheFox... is offline
Old 02-18-2008, 01:50 PM
redemption
redemption's Avatar
Default RE: Different Surging Idle Fix....
ive heard that too not sure if it works tho
redemption is offline
Old 02-18-2008, 03:07 PM
CantStopTheFox...
From some other stuff I found, they say trimming down the gasket in between the two ports works too...
I think I will try that first...before ruining my IAC
I think it essentially does the same thing as the IAC adjuster......minus the $50
Has anyone seen/tried this?
Old 02-18-2008, 05:54 PM
87Stallion
87Stallion's Avatar
Which port on the IAC do you take the dremel to? I will try it as I have 3 other IAC's laying around.
87Stallion is offline
Old 02-18-2008, 05:58 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
with mild bolt on's you shouldn't have to do such a thing.. idle surge is often a result of vaccum leaks and or the valve itself....the proper fix is to find what is causing it and not jerry rig a so called fix
mjr46 is offline
Old 02-18-2008, 06:33 PM
CantStopTheFox...
ORIGINAL: mjr46
I tell you...I have tried everything. I had it tested for vacuum leaks, replaced the IAC, MAF, EGR, EGR Spacer, TB, O2 sensors....
TPS is at .98, Reset Base Idle, Fuel Pressure is at 42....and it still surges [:@]
I am running out of ideas...at this point, the only culprit to blame is my cam (TFS 1)
The only other options are to drill the TB (will also stop my BBK whistle), and I was thinking about the IAC adjuster too...do you have any experience with it?
Old 02-18-2008, 06:35 PM
P.S.I.cho
P.S.I.cho's Avatar
check vaccumes if your running bigger injectors then stock make sure you got a clibrated MAF for those injectors
P.S.I.cho is offline
Old 02-18-2008, 06:59 PM
mjr46
mjr46's Avatar
A dyno tune can open the window of SENSITIVITY OF THE IAC to over correct.. but they make a plate with a screw in it to adjust also..worth a try
mjr46 is offline
Old 02-18-2008, 08:23 PM
CantStopTheFox...
ORIGINAL: P.S.I.cho
Had a shop test for vacuum leak....only thing they found was the EGR...replaced it, still surging...
MAF is calibrated for 24s....
I was thinking dyno tune....but there are none in my area. I am moving back to NY in a few months...there is a shop there that I definitely plan on visiting
As far as the adjuster.....I guess it is worth a try....but I hate to spend another $50 on something that makes no difference....the wife is starting to catch on
Old 02-18-2008, 08:28 PM
ericdk5.0
ericdk5.0's Avatar
Ahhh wifes, thats another thread all in it own lol
ericdk5.0 is offline
4cylinderplus2
10-09-2020 07:45 PM
TCStangerv6
10-11-2015 05:57 PM
svfetter
10-05-2015 11:39 AM
MacSerio
09-27-2015 01:05 PM
lmurf60
09-24-2015 10:07 PM
Quick Reply: Different Surging Idle Fix....
