Speedometer correction - more options?
Have a 92 LX 5.0 convertiblewith the T5 transmission. Rear end changed to 3.73. From what I have been able to determine, Ford changed the transmision drive gear from 7 tooth to 8 tooth in 90 and as a result, there is no good option for correcting the speedometer without opening the transmission and replacing the 8 tooth drive gear with a 7 tooth drive gear. I currently have a 21 tooth driven gear (red) but that still makes my speedometer read about 10-15% high. I have seen a non OEM 23 tooth gear advertised but from what I have seen on this forum, it will not last long.
What am I missing? Is there another option other than big bucks on an inline gear adapter?
Paul
Paul
RE: Speedometer correction - more options?
shifter off
knock out the roll pin in the shift block
unbolt tailhouse from main case and remove...
thats that
and... someone had a chart saying what to use with what...
what IS suposed to be used for 3.73s and an sn95 trans...?
thats that
ORIGINAL: dimebag
shifter off
thats that
shifter off
thats that
jwog666
12-27-2021 08:09 PM
