injectors
injectors
sup guys, i gotta 95 gt and i plan on doing a H/C/I swap on it. I wanted to know if i needed injectors for this combo. I plan on getting the professional product typhoon intake manifold, e303 cam, and the afr 185 heads
thanks
[/align]
RE: injectors
make sure with the 185 's you perform the proper checks to see if the stock bottom end will need the pistons flycut..and 19's will probably work but for future possible upgrades I'd put 24's in and have a good tune done
RE: injectors
it'd be ideal to add injectors then....cause it may not run to well with your combo and the 42 lb injectors if not needed.... it may run pig rich but how much boost will determine the injector size too
RE: injectors
you could turn the reg way down but really I'd build the combo n/a first then when it came time to supercharge.... pull injectors out .. ebay them and recoupe alot of the money and put that towards the 42 lb ones.......it'll save alot of headache trying to tune a mismatched combo in the meantime
