t5 question, please read
Alright my t 5 in my 88 gtis going bad...my cousin has an 84 svo 4 cylinder turbo obviously...anyways it has a t5 also.....i've heard the ratio's are better in the svo's..has anyone tried this....are they compatible... get back to me on it</P>
</P>
-1-</P><edited><editID>deacon</editID><editDate>37903.6694444444</editDate></edited>
Yes you can put a 4cyl t5 in a 5.0 mustang. You will run into a few problems though. You will need a V8 bellhousing (from your old transmission) and either an adapter bearing / bushing for the input shaft or replace the input shaft with a V8 one becauseinput shaft on the 4cyl T-5's are .590", on the V8's they are .668.</P>
Also, the gear ratios are more aggressive, but 1st gear will be SOOO steep (4.3) that it won't be usable. Also the pre 1990 T-5 are really weak. I did some research for you and this is what I found:</P>
1984 SVO T5 Gear ratio's</P>
1st = 4.30</P>
2nd = 2.37</P>
3rd = 1.50</P>
4th = 1.00</P>
5th = 0.76</P>
Torque Rating = 300 ft lbs</P>
By comparison, a 1990+ T5 has a torque rating of 300 ft lbs (and we all know how weak they are at the track) with a 1st gear ratio of 3.35</P>
Also, the World Class t5 has a torque rating of 330 ft lbs and a 1st gear ration of 2.95</P>
The point I'm trying to make is that unless you have a 4cyl car and need to get going with low torque, don't use this tranny. You will have a horrible time driving around town and it won't live longbehind V8 torque.</P>
Matt's 95 Stang
10-05-2015 07:16 AM
09-27-2015 03:16 PM
