Turn Signal Problem
Turn Signal Problem
When I turn on my turn signals just the light comes on and doesnt flash. I cant turn on the hazard lights and they will flash. I know there are two different flashers and I have replaced both of them but I dont know what else could be the problem
RE: Turn Signal Problem
I take it you already search and found nothing in the posts to match your problem? All the fuses are good? It may be a bulb causing the problem. Does the light flash when at one side and doesn't on the other side? The flasher makes the light flash. If you've checked all this you may need to visit veryuseful.com and pull out a wiring diagram. Someone had suggested before that you plug and unplug the multifunction switch a few times to clean it out. Try it.
Hoped this helps
Hoped this helps
yea i had the problem and it ended up being bulbs. connection jsut wasnt tight. if you manually flash to turn do the lights work? if they do then it has to be the flasher or the bulb. since you say you already replaced flasher than it must be the bulb. if they dont light up at all then id guess your multifucnction is bad. check the bulbs first though
musnicki
09-23-2015 07:11 AM
