Engine year
RE: Engine year
What heads are on it? If they are heads from whatever the motor came from you can tell, there will be a serial number like E7TE, It will be under the valve covers. go to google and type in Ford serial numbers or casting numbers and there will be a few sites to tell you what they mean
RE: Engine year
RE: Engine year
up on the block at the back right above the starter there will be a casting number...yours should of started out like this e7te....... and may still have this casting code or f1...casting code in 91 the casting code switched to F1......
KEM Motorworks
08-14-2015 10:13 PM
