Compression ratio?
Old 02-22-2008, 11:12 AM
djcondo
djcondo's Avatar
Default Compression ratio?
what would the highest compression ratio that i can run on a basically stock engine. im trying to plan a rebuild with a little more. i was thinking ported gt40p, .0040 over, stock cam or somthing smaller, and an eldebrock performer intake and carb setup. and i will be using pump gas. with the higher the compression ratio the higher grade gas, so i was wondering how high should i go to be safe and still use pump gas
djcondo is offline
Old 02-22-2008, 11:30 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: Compression ratio?
ORIGINAL: djcondo
wow what a jumbled mess^^^^ first of all with flat top pistons and gt-40p head you'll be well with in the realm of pump gas at best 9.5 with that set up..running aluminum heads will allow a higher compression ratio to be run without detonation.. I ran .200 dome piston with 58 cc afr heads and came in at 11 to 1 on pump gas with no issues.. but around 11 to 1 is a safe level with aluminum heads of course and if your block is stock bore the typical over bore is to .030 not a .0040.. I think you may have meant .040
mjr46 is offline
Old 02-22-2008, 11:46 AM
djcondo
djcondo's Avatar
yeah i hit the zero once to many. why do the alum head allow higher compression? Also wont i notice a resonable differeance with the raised ratio? sorry the first mesage was all over the place
djcondo is offline
Old 02-22-2008, 11:55 AM
mjr46
mjr46's Avatar
aluminum disipates heat quicker than cast iron and thus is less prone to hot spots in the cumbustion chamber.....spark detonation is a result of excessive cumbustion chamber temps..and it depends on how much you raise it vs how much seat of the pants feel you will notice.....I went from 9.7 to 11 to 1 and there was a huge difference but going from like 9 to 1 to 9.3.. not really noticable
mjr46 is offline
Old 02-22-2008, 02:08 PM
djcondo
djcondo's Avatar
yeah i was looking to go from stock cr to like 10:1 or like at the most 10.5:1. looks like i would need alum heads. thanks
djcondo is offline
Old 02-22-2008, 02:20 PM
5spd GT
5spd GT's Avatar
The camshaft is going to come into play when you start increasing the static compression.
You should have no issues.
5spd GT is offline
Old 02-22-2008, 04:12 PM
irish1
irish1's Avatar
You could take a pair of stock E7s, have thumper work his magic on them and get with a cam grinder like Jay Allen and have parts which played together nicely. I'd rather spend 1000 bucks once and have it run great then spend 750, have it run not so hotand then have to redo it for another1000. Cheaper/better to do it right once.
Matt
irish1 is offline
Old 02-22-2008, 11:39 PM
djcondo
djcondo's Avatar
cool thanks.
djcondo is offline
Jb145700
08-21-2022 06:37 AM
baddog671
07-26-2016 01:20 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
bconboy
09-21-2015 12:52 PM
uberstang1
09-20-2015 06:42 PM
Quick Reply: Compression ratio?
