Current combo:
93 lx ssp
A9L computer
Fully ported Cobra intake w/ 65 mm tb
24lb injectors
Fully ported gt40 iron 3 angle valve job flows around 230-235 if I remember correctly
b-303 with 1.7's
Which cam would you guys run and what power are you getting?
thanks
I'm farmiliar with the e303 but would prefer to go with a more modern grind.Has anyone else used/tested any of the comp cams shelf grinds? Also, what power are you making?
you can get alot of stage 1 type cams that will pass smog no problem WITH a dyno tune. its not like your smog guys is gonna know you have an aftemarket cam in there.
