rear main seal
rear main seal
the rear main seal is leaking on my 90 lx and i was told you have to pull the motor to replace the oil pan gasket so i was wondering if you have to pull the motor to replace the rear main seal as well or if you can do it in the car by pullin the tranny back thanks in advance
RE: rear main seal
The motor can be raised high enough to replace the oil pan gasket,os on you don't need too pull the motor to replace the oil pan gasket.
Rear main== Remove the driveshaft, exhaust, transmission, bell housing, pressure plate and clutch, and then replace the rear main. Again no reason to pull the motor to put in a rear main.
09-16-2015 07:53 PM
