rattle sound 1600 rpm
rattle sound at between 1600 rpm 2000rpmcheck engine light flashes says fuel to lean to compensate cuts off at times during idle replaced fuel pump, regulator, cap wires, plugs coil problem started after fuel pump went bad then coil was sparking replaced it also fuel pressure was still low so replaced regulator also replaced timing chain and balancer because chain had slack and the balancer was spun any ideas on how to help my tired 95 5.0 mustang gt with 2.70 rear end
AmericanMuscle4.6GT
11-10-2015 02:06 PM
movielover40
09-15-2015 10:37 AM
