Tire Pressure 245/45/17
Old 02-24-2008, 06:01 PM
tmajikman
tmajikman's Avatar
Default RE: Tire Pressure 245/45/17
I ran the car today with 32 psi and it rode great. 40 psi made the car ride quite rough.
tmajikman is offline
Old 02-24-2008, 06:05 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: tmajikman
PRO50SC is offline
Old 02-24-2008, 06:16 PM
golden_eye
golden_eye's Avatar
ORIGINAL: OnyxCobra
Too much pressure can also wear the tire unevenly.
True... On the flipside, too little pressure will also cause uneven wear . Usually anything b/t 30-40 won't hurtour tires. I know lots of people go into the 20s for the strip (I've heard it argued that it doesn't help as much on street tires, though)but I wouldn't run around on that all the time [8D].
golden_eye is offline
Old 02-24-2008, 06:39 PM
tmajikman
tmajikman's Avatar
I agree you have to have the proper amount of air in atire or you will either wear out the middle of the tire or you will wear the edges of tire out quicker, 32 gave the car a good ride, I would rather sacrifice a small amount of mileage instead of my body.
Old 02-24-2008, 07:02 PM
OnyxCobra
OnyxCobra's Avatar
A tire's max pressure doesn't really mean anything except don't put more than that in the tire, it's not a recommendation about how much pressure to run in them. 32psi is probably right on the money.
OnyxCobra is offline
Old 02-24-2008, 07:12 PM
94Yellow50
94Yellow50's Avatar
hmm..i run about 30/28 front/back...thats with 275/40 on front n 315/35 on back...i chalked the tires n the wear pattern is even across the whole tire...my only problem with wear is the back lol..they seem to be going faster than the front for some "unknown" reason
94Yellow50 is offline
Old 02-26-2008, 09:44 PM
Bullitt91
Bullitt91's Avatar
i have the same tires and i run 35 psi. seems to be the happy medium.
Bullitt91 is offline
Old 02-27-2008, 08:22 PM
Jfsram
Jfsram's Avatar
ORIGINAL: OnyxCobra
Another reason to back up this statement is. The manufacture has no idea what car these tires are going onto. How can they recommend a pressure. Like Onyx said, it's only an upper saftey limit.
Jfsram is offline
jwog666
12-27-2021 08:09 PM
CS2007
06-25-2019 09:45 PM
svfetter
10-05-2015 11:39 AM
88 orangepeel notch
10-05-2015 09:03 AM
marc954
09-29-2015 11:18 AM
Quick Reply: Tire Pressure 245/45/17
