timming question
Old 02-24-2008, 01:52 PM
warggod
warggod's Avatar
Default timming question
PRO50SC
How To: Properly stab your distributorok i went by how he was doing when i line up the mark on the block and dis. and slide it in
i can not turn it back to that other mark he says is the 10 degree mark i only make it half way before my vacuum advance hits my water neck...
89 302 stealth maniflod carb motor what do i do
warggod is offline
Old 02-24-2008, 02:13 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Default RE: timming question
Get some pics and let the rest of us see your problem. What year dizzy are you using???
projectresto83 is offline
Old 02-24-2008, 03:43 PM
warggod
warggod's Avatar
ok 85 duraspark 2
warggod is offline
Old 02-24-2008, 03:49 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
you may need to turn the oil pump driveshaft a little with a 1/4 inch socket and drive so it'll drop right in
mjr46 is offline
warggod
warggod's Avatar
i uploaded a pic heres a another one
warggod is offline
Old 02-24-2008, 03:50 PM
mjr46
mjr46's Avatar
no pic link didn't work[&:]
mjr46 is offline
Old 02-24-2008, 03:53 PM
warggod
warggod's Avatar
it worked for me i will try what you said about pump shaft also on the ajustment on the pedistal rollor rockers i have im setting the preload is it a half turn to full turn max because im in the middle of shimming them right now it seems that im shimmimg the exhaust and not the intake
i get about a 1turn if not a hair more with the intake and 1/2 to 3/4 with the exhaust
warggod is offline
Old 02-24-2008, 03:56 PM
mjr46
mjr46's Avatar
your off a tooth or two .....needs to point more towards straight back! restab again!
mjr46 is offline
Old 02-24-2008, 03:59 PM
warggod
warggod's Avatar
but when i do that i cant move it back to 10 degrees on the block
warggod is offline
Old 02-24-2008, 04:04 PM
warggod
warggod's Avatar
ok what about this when i start it then shut it off then come back to start it i turn the key to the on position i here a puff like some gas is igniting the car does have a electric fuel pump do i need a regulator
warggod is offline
Quick Reply: timming question
