E303 cam in stock motor
Old 02-25-2008, 10:59 AM
Projectquick
Projectquick's Avatar
Default E303 cam in stock motor
Itook my car to a mechanic friend to find out if the car has a cam or not. He suggested the same method as someone suggested here of seeing how much the pushrod actually lifts and comparing it to the lift specs of the stock cam. After pulling the valve cover and removing one of the rockers the guy I bought that car called and said he got in touch with his engine builder and said that the engine was rebuilt to stock specs except for the addition of a Ford Racing E 303 cam. My question is does this cam actually help on a stock engine? If not what does it hurt? I have always heard that the E cam is not even worth itwhen upgrading the top end, but was wondering if it made any difference on a stock motor.
Projectquick is offline
Old 02-25-2008, 11:06 AM
mustangcobra94
mustangcobra94's Avatar
Default RE: E303 cam in stock motor
projectquick, out of curiosity cause i'm thinking of doing a cam, how does the e303 sound as far as idle and what not... im looking for that rougher idle sound
mustangcobra94 is offline
Old 02-25-2008, 11:11 AM
Projectquick
The idle sounds rough, but not crazy. If you didn't know what you were hearing it would sound like it's running ****ty. You can definitely hear it though.
Old 02-25-2008, 11:13 AM
mustangcobra94
alright thanks man
Old 02-25-2008, 11:19 AM
PJC Racing
PJC Racing's Avatar
At a minimum the stock valve springs should be upgraded for the cam.
PJC Racing is offline
Old 02-25-2008, 11:45 AM
aode08
aode08's Avatar
ORIGINAL: PJC Racing
you can rent a air compressor and use it with an attachment thats screws into your spark plug hole to hold your valves up as you remove the springs(heads on car, valve covers off).
Or you can bring the cyl to tdc and stuff nylon rope in there(takes a lil longer).
aode08 is offline
Old 02-25-2008, 12:02 PM
drhoward
Penis Mod Erator
drhoward's Avatar
its not really going to help you all that much in the hp department....I don't think it is really going to hurt anything though
drhoward is online now
Old 02-25-2008, 12:19 PM
Projectquick
Ah, so basically its just there to make my car sound like its running ****ty to all outside observers. Sweet![&:]
Old 02-25-2008, 12:29 PM
drhoward
Penis Mod Erator
drhoward's Avatar
well most cams that you put in there are going to make it sound like that, my tfs1 cam does the same thing (with my heads and intake)
I would just leave it, they are decent enough cams and if you are planning on swapping everythinng anyways, it saves you a bit of work
But its up to you
Old 02-25-2008, 12:47 PM
Projectquick
I planned on leaving it anyway. As soon as it warm enough the car is going to see a substantial power increase wether its H/C/I or Nitrous it will be a 12 second 5 sp fox.
Quick Reply: E303 cam in stock motor
