Thermo Housing Leaking??
My buddy replaced his Thermo.....and it is leaking a lot!
I am going ot go over there after work to check it out, but I was wondering if you guys have any ideas??
I know the torque specs are 15-20lbs.......so I think he over-torqued it. I asked him if there is any corrosion on it and he said no.......what else could it be?
I am going to cut a new gasket with some gasket material I have, and then goop it up with some gasket sealant. Then I am going to torque it properly to the right specs..........am I missing anything??
I just don't understand what he could of done...it is not that hard to change a thermo?!?
RE: Thermo Housing Leaking??
more then likely the thermostate dropped down from where it was suppose to be and is pinched in between the housing and the mounting surface. i just replaced mine last week and i had the same problem. i stuck a piece of wire down threw the housing and held the thermostate up while i tightened the bolts and it didnt leak at all. try that and see if it works.
I just replaced my thermostat last week. The Ford design is a little tricky, so here is what i did:
-seal the thermostat to the housing with RTV (Blue Permatex)
-then seal the gasket to the housing
- wait about 20-30 minutes for the sealant to set a little bit and reattach the housing
Keep in mind that the directions on the RTV say that it takes 24 hours for the RTV to fully cure. I don't think you need to wait that long as you shouldn't be using a whole lot here, but its up to you. Good luck!
f the torque spec!! just tighten it so it's tight!! and make sure the housing isn't warped and that he used sealant with the gasket and upper clamp is tightened sufficiently
bradleyb
11-27-2015 07:50 PM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
