Can't get 'er into gear! - help?
Old 02-26-2008, 10:01 PM
roadfrog
roadfrog's Avatar
Default Can't get 'er into gear! - help?
Hey there folks,
I just reaquired my old 88GT vert (5 spd manual) and I have a big problem which I humby request your help with....
I cannot get it into gear. It has a brand new Ford Racing clutch kit and a tranny from a wrecking yard. It worked fine the first few days, but now with the engine running, she won't go into any gear, including reverse. With the engine off, I can put it in gear, start it up and release the clutch normally and away she goes, but no shifting up from there. Is this a tranny problem (*gasp*)? clutch cable? fluid? something simple (please!)
I'm new to this site, but look forward to exchanging ideas and information. I'm just not a transmission guy.
Thanks!
Chris
roadfrog is offline
Old 02-26-2008, 10:51 PM
kennebellgt
kennebellgt's Avatar
Default RE: Can't get 'er into gear! - help?
Clutch adjustment or maybe bad syncro have you adjusted the clutch cable?
kennebellgt is offline
Old 02-26-2008, 11:03 PM
Hung Like a Stang
Hung Like a Stang's Avatar
seems like its a clutch adjustment. Are you still using the stock quadrant? If so, you gotta ratchet it back down becuaue it adjusts for wear from the old clutch.
Hung Like a Stang is offline
Old 02-27-2008, 08:19 PM
roadfrog
roadfrog's Avatar
Thanx for the replies folks,
I attempted to adjust the clutch as described in the manual, ie: pulling up on the clutch to allow the pawl and ratchet to do it's thing. No clicking noises heard.
FWIW, the clutch releases right at the floor, so it sounds like it needs adjusting. What now? I am DYING to get my Stang on the road again after 5 years......
roadfrog is offline
Old 02-27-2008, 08:20 PM
Jfsram
Jfsram's Avatar
How far off the floor is the pedal when the clutch starts engaging.
Jfsram is offline
Old 02-27-2008, 08:30 PM
nseoi
nseoi's Avatar
get an aftermarket aluminum quadrant along with an ajustable cable. that should fix your problems and you can set it however you like
nseoi is offline
Old 02-27-2008, 08:41 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
sounds like an adjustment issue.....you need to stick your head under the dash and inspect the quadrant for ant broken pieces and or proper function
mjr46 is offline
Old 02-27-2008, 08:46 PM
kennebellgt
adjust it under the tranny..
Old 02-28-2008, 06:06 PM
roadfrog
roadfrog's Avatar
UGH. Well, I had a look under the dash but didn't see anything obvious with the quadrant or at the tranny. Cable goes into a box attached to the trans, but do I remove the box to adjust it there? Any specifics on how to adjust the cable? Photos maybe? I have two shop manuals, but they're pretty vague. Thanx for your patience!
roadfrog is offline
Old 03-07-2008, 09:53 AM
roadfrog
roadfrog's Avatar
Well, it WAS the clutch cable, so I replaced it with a Granatelli Motorsports cable and quadrant kit. 60 bucks later, all is good! Works great!
thanx for all the help folks!
roadfrog is offline
Quick Reply: Can't get 'er into gear! - help?
