For those that installed aftermarket dash gauges i need help asap *****
Old 02-27-2008, 10:00 PM
CantStopTheFox...
CantStopTheFox...'s Avatar
Default RE: For those that installed aftermarket dash gauges i need help asap *****
When I did mine, I was able to pull it out enough to slip my hand back there, and release the speedo cable. It was a pain, but it was possible......
Then when I was done, I started the car and all my needles were off [:@]
I recommend starting it up before you put everything back together to make sure your needles are where they are supposed to be
CantStopTheFox... is offline
Old 02-27-2008, 10:06 PM
hayden
hayden's Avatar
Same here... definetly make sure you check the needles before you put everything back together
hayden is offline
Old 02-27-2008, 10:22 PM
silver91gt
silver91gt's Avatar
I just pulled the right side of it back far enough to get my hand behind it, then undo the speedo cable, and then theres lots of room.
silver91gt is offline
Old 02-27-2008, 10:56 PM
RedMachAndOrangeFox
RedMachAndOrangeFox's Avatar
does anyone have recomendations for the needels when you take them off such as having a full tank of gas and marking where they are on the old faces???
RedMachAndOrangeFox is offline
Old 02-27-2008, 11:57 PM
worm2500
worm2500's Avatar
when i did mine i started the car and let it get up to temp, then took the needels off. that way you know exactly where every needle should be.
worm2500 is offline
Old 02-28-2008, 02:06 AM
westcoastpj
westcoastpj's Avatar
how far are you getting?theres a 'sequence' i guess you can say.take the plug thats at the bottom right side of the cluster first.then the one at the top left then the speed.Now if you dont have enough slack to fit your fingers through,try using a long screwdriver at the edges of the plugs.The plugs come out pretty easily
westcoastpj is offline
Old 02-28-2008, 12:04 PM
rust_stang
I ♥ Acer
rust_stang's Avatar
ORIGINAL: westcoastpj
ok thanks, ya i can just reach the bottom right one. then for the speed (that long pole looking thing) how do i take that apart?
also one last thing the ebay white face gauges i bought have like wires hooked up to the bottom the the slides i guess you would call them....do i even need them cuz i thought the old ones are just the slides you pop off then you place in the new white ones?
rust_stang is offline
Old 02-28-2008, 04:11 PM
rust_stang
I ♥ Acer
rust_stang's Avatar
bump.
Old 02-28-2008, 04:28 PM
9tyfiveo
9tyfiveo's Avatar
basically, trial and error. its a bitch but well worth it. just keep trying. dont talk, just do. that's what i finally had to do. my brother wouldn't help me so i just kept trying, it worked!
9tyfiveo is offline
Old 02-28-2008, 04:37 PM
Bullitt91
Bullitt91's Avatar
to get the spedo cable off u squeeze the outer ring slightly while u twist and pull. getting it out isnt the hard part its putting it back in, my cable the actual cable on the inside kept pushing down in and it wouldnt hook up. it was a pain but like 9tyfiveo said u just kinda have to do it till u get it right.
Bullitt91 is offline
Quick Reply: For those that installed aftermarket dash gauges i need help asap *****
