idle control....again Rough Idle
Old 02-28-2008, 02:20 PM
9tyfiveo
9tyfiveo's Avatar
Default idle control....again Rough Idle
so after a while of the surging idle happening more and more often, i found a voltmeter laying around and checked it(TPS), after setting it to where it should be no more problems. great! anyways last night i put in new plugs(autolites) cap &rotor, and powermax lifetime spark plug wires thinking that would solve the rough idle. last night &today, same probelm. for about the past week it has been a lower idle (about 600rpm) so when slowly letting out the cluch it huffs and trys to stall just to try and move in first gear. You HAVE to give it a little gas to keep it from stalling when taking off (gas and clutch combo). it does not matter how slow you let the clutch out. now the strange thing is that if you tap the gas a little and let the rpms come back down it goes to about 800-900 rpms and stays there for about 3-4 seconds, then finally goes back down to 600ish. (this is without moving, Idle is still rough at 800). any help would be great, if you need any other information just ask!
9tyfiveo is offline
Old 02-28-2008, 03:05 PM
Hawk
Hawk's Avatar
Default RE: idle control....again Rough Idle
Have you checked your base timing and if so, have you tried bumping it abit to see if it helps pick the idle up?
Hawk is offline
Old 02-28-2008, 03:36 PM
9tyfiveo
9tyfiveo's Avatar
i bumped it about two months ago. its slowly running worse and worse. ill give this a try again though... any other suggestions? what can i do to make sure everything is running properly? clean what? replace what?
9tyfiveo is offline
Old 02-28-2008, 03:39 PM
TTGreenSN95
TTGreenSN95's Avatar
ORIGINAL: 9tyfiveo
Is the car itself running worse like losing power? or is it just you idle?
TTGreenSN95 is offline
Old 02-28-2008, 03:54 PM
9tyfiveo
9tyfiveo's Avatar
ORIGINAL: TTGreenSN95
ORIGINAL: 9tyfiveo
runs fine, just rough idle, and it wants to fall on its face when i try to take off anymore without giving it gas and basicallyslipping the clutch.
9tyfiveo is offline
Old 02-28-2008, 05:52 PM
TTGreenSN95
Man I know its a pain in the butt I had the same problem
I had to open my butterfly a little and reset the tps it idles at 900 but it idles!
Thats all I got man hope you get it right!
Old 02-28-2008, 06:03 PM
comets7779
comets7779's Avatar
I had a similar problem but mine was a surging idle and used to cut out if i didnt peddle it, Got my idler plates moved up seems to hold idle pretty well now not a 100% but thats probably an idea for you if you cant find out the problem
comets7779 is offline
Old 02-28-2008, 06:08 PM
9tyfiveo
9tyfiveo's Avatar
i appreciate the help, but i guess a little trial and error seems to help a little anytime your troubleshooting, but so does questions and suggestions. anyone else throw in $.02?
9tyfiveo is offline
Old 02-28-2008, 06:23 PM
littlebluelx
littlebluelx's Avatar
Something I have started to learn is pull the codes. If your check engine light is on there is most likly a reson for it. now mine is always on because I no longer am running Egr ,smog and Ac but it still will help you out.
Will
littlebluelx is offline
GimpyHSHS
19
12-19-2023 01:12 PM
4cylinderplus2
10-09-2020 07:45 PM
TCStangerv6
10-11-2015 05:57 PM
svfetter
10-05-2015 11:39 AM
MacSerio
09-27-2015 01:05 PM
Quick Reply: idle control....again Rough Idle
