BBK SI INTAKE
Old 02-28-2008, 09:27 PM
19stang86
19stang86's Avatar
Default RE: BBK SI INTAKE
Hey I appreciate the info. But do i have to change the heads for it to fit? because someone was saying earlier it has e6's on it and its ment to fit e7's is that true?
19stang86 is offline
Old 02-28-2008, 10:09 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
bbk ssi out of the performance intakes is the low man on the totem pole as far as max power output potential
mjr46 is offline
Old 02-29-2008, 02:35 AM
Tberg725
Tberg725's Avatar
Herd nothing but bad things. I dunno why everyone looks down on the GT-40 intake it flows better then just about every aftermarket intake upto 5500rpm.
Tberg725 is offline
Old 02-29-2008, 08:27 AM
89musclestang
89musclestang's Avatar
to answer your head question. i just read about it in my mustang handbook the e6 for some reason aren't as good as the e7's its about a 25 horsepower difference(and thats the difference between the H.O and non H.O) and in 1985 they started making all the 5 liter engines with roller cams so you wouldn't have to switch the cam you just need to find yourself some e7 heads on anything from 1987 and up
89musclestang is offline
Old 02-29-2008, 10:21 AM
86302gt
86302gt's Avatar
ya they changed the heads in 85 to 86 for better emissions and it drop hp and tq but than changed them back in 87 to the 85stang heads but in 86 they were still ho just good emissions ho just read this it will explain it a lil more http://www.mustanggt.org/86gt.htm
86302gt is offline
Old 02-29-2008, 10:30 AM
r.barn
r.barn's Avatar
Had one, they suck
r.barn is offline
Old 02-29-2008, 10:51 AM
WhiteWindsor
WhiteWindsor's Avatar
Ordered two of them[:'(][:'(]. Sent them back before i installed them.
WhiteWindsor is offline
Old 02-29-2008, 07:39 PM
white93pony
white93pony's Avatar
i have one and it is one ofthe best intakes on themarket in my opinion. on my old car stock engine with just exhaust and edlebrock performer it put down 221 and 270 at the wheels it would run a 13.5 with slicks and 3.73 gears. i changed to the bbk and power went to 228 and 287 at the wheels and times went to a 13.3 all i did was changed the intake. all the tests ive seen it has outperformed all others except the holley they were about the same. i current have an ssi with adjustable regulator im selling because i sold the fox and bought an sn95 car and it wont clear the strut tower brace and hood and do not wanna remove the brace. i wish it would fit but it wont i called bbk and they are currently not making a brace that will clear so im stuck!!!
white93pony is offline
Old 02-29-2008, 08:54 PM
19stang86
19stang86's Avatar
So the ssi intake wont fit on the e6 heads? So i need to get heads, cam and il be good?
Old 02-29-2008, 10:40 PM
r.barn
r.barn's Avatar
SSI intake is a pile of crap.
Get an Edlebrock RPM-II or Trickflow StreetHeat intake.
Mo-betta and less money.
Problems I had with SSI.
1. Hits stock hood - not bad but does hit
2. IAC motor did not fit - had to grind on intake
3. sucks oil thru PCV
4. Flows like crap
5. Whistles at idle
6. LOTS of casting flash that had to be ground down
7. Cost $200 more than other better intakes
and on and on.
r.barn is offline
Quick Reply: BBK SI INTAKE
