Replacing Head gasket question. Help!
Old 03-01-2008, 12:51 AM
MilkMachine
MilkMachine's Avatar
Default RE: Replacing Head gasket question. Help!
oil is milky, burns tons of white smoke, compression is down. trust me I know its the gasket my good friends.
MilkMachine is offline
Old 03-01-2008, 01:41 AM
PJC Racing
PJC Racing's Avatar
If you have done 4cyl's there realy isn't too much difference. You just have two to do.
PJC Racing is offline
Old 03-01-2008, 12:13 PM
JumpInTheFire.com
JumpInTheFire.com's Avatar
actually..i forgot earlier in my post, but on mine.. i put a bottle of a sealer in my car and it doesnt smoke anymore.
it did smoke when i caught my dead grass underneath it on fire though.
but yea i put a bottle in it and it doesnt smoke anymore. i drove it earlier. pretty amazing. i dont know how long it'll last.
since you're gonna change the gaskets anyway. try a bottle first. on the bottle it says it'll seal up blocks, head gaskets, radiator leaks,etc.
JumpInTheFire.com is offline
Old 03-01-2008, 12:15 PM
JumpInTheFire.com
i was missing a little coolant when i checked mine but i tightened something up and it dont leak anymore.
check your freeze plugs they might leak a little. i had to replace 2 mine already.
Old 03-01-2008, 02:10 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
ORIGINAL: MilkMachine
ARE YOU POSITIVE IT'S THE HEAD GASKET?? you sure it's not an intake gasket?? what about a timing cover gasket???......all these have areas where coolant can mix with the oil... there is actually less spots on the head gasket that can do such... after overheating it probably does have bad gaskets but don't overlook the timing cover cause I had one recently where the water pump impeller broke a piece off and knicked the inside of the cover causing a leak from there to inside the block.. oil was milky.....intake won't matter since you gotta pull it to do heads...but just a thought
mjr46 is offline
Luke9222
10-22-2015 11:55 PM
bconboy
09-21-2015 12:52 PM
cbird1177711
09-03-2015 08:43 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: Replacing Head gasket question. Help!
