dies when u give it gas
runs smooth and idles steady but when gas is applied, the motor begins to bog and almost dies.
any idea's?
its getting fuel.. maybe too much.
my friend mentioned possible vaccum leak? but it idles good?
im lost here........
any idea's?
RE: dies when u give it gas
yes it has codes and yes it has stock cats (4 of them)
smog pump was unhooked when i got car.. but still belt driven.
23 - TP sensor out of self-test range
63 - TP circuit below minimum voltage
67 - Neutral/drive switch open or A/C on
67 - Clutch switch circuit failure
67 - MLP sensor out of range or A/C on (E4OD)
81 - Air management 2 circuit failure
Once past 2k rpm's, CEL goes away and car rips hard...
Gunna slap my 75mm maf and 65mm throttle body on tomorrow.
