afr's and tfs stage 2 on stock bottem end?
#21
RE: afr's and tfs stage 2 on stock bottem end?
ORIGINAL: FullAuto
I used TFS-5140002 @ $1199. That's 17.5% and I said ~20%. Don't worry though, I didn't expect you to be familiar with the TFS side.
You don't think the TW 170cc is a fair comparision to the AFR 185cc? Let's compare it the 165cc then. The TW is cheaper andhas more flow,more cross section, miles upon miles more potential. If someone was looking for a 185cc head, the TW at 185cc kills the AFR for the extra $400.
I like how you keep preaching about those valves and springs. When did those become standard for AFR? Was the AFR just run-of-the-mill prior to these upgrades?
The fact is at all differentlevels the Twisted Wedge can be ordered, it can compete with ALL the FULL CNC AFRs. That's just a single casting Trick Flow offers.Bringthe TFS S/H into the mix and AFR gets their feelings hurt.
AFR 165: 2.013
TW 170: 2.184
AFR 185: 2.257
I am also trying to keep the heads as equally equipped. I am not going to putthe cheapest.550" valvetrain cylinder head at 170cc, and compare it to a AFR 185cc with a .600" lift spring. I compared them with the same springs, to make it more apples to apples, and not apples to oranges.
So it is still a 7-8% difference, and the AFR heads have full CNC ports and chambers. Ask Onyx what he thinks of them. I have had a couple sets in my hands before.
To quote Jay Allen from a thread a couple years ago:
"The TW design is a failed Pro Stock design that Pontiac tried in the late 1980's. It moves a ***** load of air, but the air is confused and twists and turns. ie, swirl. Swirl is for low piston speeds, emmission friendly applications. It does NOT make power. " - Jay Allen.
AFR'shave a lighter valvetrain and lighter springs modeled after the LS1. This increases the capabilities and RPM limits OOTB.
You are comparing the heads you want to compare.
The AFR heads swapped recently, just a few months ago. It is currently the current time period, right?
We buy heads now, not one year ago.
You trash AFR on a regular basis. I compare them on a regular basis.
I look forward to comments.
I am glad you are keeping this level headed. To many times, people make personal attacks.
What do you think?
#22
Lighter valvetrain is nice...
A quote:
"I don't recall the exact "ballpark" for grams saved v. greater rpm capability but I believe it is something like 1 gram = 10 rpm... I am sure there are many variables that come into play as well...
I run a solid flat tappet cam and switched to a set of PAC beehives from Ed. Prior to the beehives I was using a Comp 929. We are required to use steel retainers per class rules...
The following are the weights of the components...
Comp 929 retainer and 10* lock: 37 grams
Beehive retainer and 7* lock: 14.5 grams
Comp 929 spring: 151.5 grams
Beehive spring: 95.5 grams
I had the 929's set up with ~155lbs on the seat and ~400lbs over the nose. The engine would go into valve float around 7400 rpm. The springs would drop ~20lbs of seat pressure after the first "run in" and I would have to shim them back up...
With the beehives I run ~150lbs on the seat and ~370lbs over the nose. I shift at 7600 rpm and go through the traps at about 7900 rpm. There are absolutely no signs of float. After 34 passes the beehives have not lost one pound of seat pressure. Even better news, no more broken up Ferrea valves..."
A quote:
#23
If this is true, why is the TW head the #1 head used in NMRA?
For ahead that does not make power, please explain to me how Phil Clemmons managed to make several 7 secondpasses with a street TW head equipped engine?
While I do realize Phils heads were not " As cast OTB heads" theystill maintained the stock TFS port and valve locations.
#25
you guys never stop amazing me, looking at what trick flow did for the bbf back in the late 80's early 90's with the invent of the A head and the B "bastard pro stock head" that too quote a legendary engine builder "was years ahead of its time, and there have been heads only recently that have caught up to its max flow and power efforts." -Paul Kane. trick flow bleeds ford blue and I wouldnt buy heads from anyone else if it were me for a bbf and even the small block. Trick flows "failed pro Stock", thats bs, I dont care who said it. Well why dont you ask bob glidden what he thought of the trick flow heads? And if you dont know who bob glidden is then dont bother reading anymore.
ORIGINAL: TrickFlowTech
#27
EDIT: heres the source
However, there was a downside to the changes to the ‘86 5.0L. From 1968 through 1985, the 302 small blocks had used a wedge-type cylinder head. When that head was dropped in '86 in favor of a new casting which Ford called a high-swirl, shrouded valve head, (although the new head greatly improved emissions ratings) performance fell because the head design restricted volumetric flow.
#28
ORIGINAL: 5spd GT
You spoke of cross section above, right?
AFR 165: 2.013
TW 170: 2.184
AFR 185: 2.257
AFR 165: 2.013
TW 170: 2.184
AFR 185: 2.257
ORIGINAL: 5spd GT
ORIGINAL: 5spd GT
ORIGINAL: 5spd GT
This arguement I will admit is a little better than the side loading and rod ratio arguements you used to preach about. Sure, there is some factual basis for this claim, but reality is, you're trying to promote increased valvetrain capabilities and RPM limits to people who are running SADI cams with their 6250 rev limiters and saying it was modeled after a motor that uses a 55mm billet steel cam that could see the benefits of the differences. The customers these heads target will likely never see any difference, and an overwhelming majority of them don't understand what is potentially to be gained nor would care about it if they did understand.
ORIGINAL: 5spd GT
ORIGINAL: 5spd GT
ORIGINAL: 5spd GT
ORIGINAL: 5spd GT
What do you think?
What do you think?
#30
As a sponsor on this site is I am here to talk about my products and inform potential customers of the products we offer. As far as arguing with AFR goes, we are not high school rivalries. We have a good working relationship with the gentlemen at AFR.
Fullauto: You are a wealth of knowledge and i enjoy reading your post, i value your opinion and respect what you have to say. You were missed by myself when you left for a while. I heard various things as you reason for leaving. Whatever they were, i dont care. I hope you stay involved. We have really gotten some great members to join us recently and i'm glad for it. Jasper sent me a pm a couple of weeks ago saying this was going to happen. If he made this possible then my props to him and if not i'm sure he'll take credit for it. I dont want to leave Woodsy out either, he has been awesome. To anyone else i'm forgetting, i'm glad to you on board so we can pick your brain.
