Shifter Vibrates very bad at over 75 mph
Old 03-06-2008, 08:10 PM
bighungrymatt
bighungrymatt's Avatar
Default RE: Shifter Vibrates very bad at over 75 mph
I would check U joints
bighungrymatt is offline
Old 03-06-2008, 08:26 PM
Dilireus
Dilireus's Avatar
Since the vibration increases with vehicle speed (as opposed to engine speed), it's almost definitely your driveshaft. If you've ever had the driveshaft off, you should check to make sure the bolts haven't worked themselves loose. It would ruin your whole day to have it come off.
Dilireus is offline
Old 03-07-2008, 05:50 PM
tmajikman
tmajikman's Avatar
I found out the piece of rubber that connects to the trans and the crossmember is broken and tore up pretty bad. What would be a good replacement for that rubber piece and should I replace anything else that is part of the crossmember? Where can I also find these items, Thanks
tmajikman is offline
Old 03-07-2008, 07:31 PM
nitrous_bob
nitrous_bob's Avatar
* energy suspension *
just a note on the stop bolts...b&m has stopped using them, too many poeple setting them incorectly, for 1...they should not be touching the shifter if your hand is not on it....they are to keep you from overshifting only....not to hold the shifter in place
they should allow only a slight overshift....just so you don't break a shift fork or anything...but then stop it, so vibration should not be an issue w/ them or you have them set too far
nitrous_bob is offline
Old 03-07-2008, 09:00 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
yep ^^^energy suspension ftw!!!
mjr46 is offline
mtgldr
02-03-2024 09:00 PM
bjdutch2005
03-24-2017 03:38 AM
carid
07-08-2016 09:55 AM
ccdguy
09-19-2015 05:20 PM
09-16-2015 07:53 PM
Quick Reply: Shifter Vibrates very bad at over 75 mph
