x cam ??
Old 03-08-2008, 07:22 AM
  #21
Joel5.0
Joel5.0's Avatar
Default RE: x cam ??
ORIGINAL: 89mustangfive0
not trying to go fast cheap..i was told use an x-cam i have achance to get one im asking if i should or not simple question.....didnt need a life lesson what cam do you suggest i run...i was told x then steeda 19 then steeda 18..also was told that a custom cam is useless for me based ont he fact ill be driving at night and weekends plus theres no track out here so im buying performer 5.0s as stated what cam should i get?
A custom cam useless?.......LOL.... Custom cams get the "competion only" tag wrongly..... a custom cam will not only be a better performing cam, but also a better driveable setup (if so specified/required). The X-303 = B-303 in terms of valve events @.050", same overlap, but more "lift under the curve".........the camshaft I would suggest is a CI custom tailored for your combo.
Joel5.0 is offline
Old 03-08-2008, 09:01 AM
  #22
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
^^^exactly a custom cam can be just as streetable as a ots cam also a custom cam will be matched to your whole combo
mjr46 is offline
Old 03-08-2008, 09:26 AM
  #23
w8less
w8less's Avatar
the X cam does need to have pistons flycut seen that done that
w8less is offline
Old 03-08-2008, 10:02 AM
  #24
Joel5.0
Joel5.0's Avatar
ORIGINAL: Jasperstang308
Every setup is different and you should always check clearance, but in terms of PtV problem possibilities...... the X-303 ~ B-303. Valve events @.050" are identical for both. By the same token, my junk has an X-303 with 1.72 rockers....... never had a problem clearing. Same goes with other X-303 installations I've done or checked after the fact (done elsewhere w/out checking).
Joel5.0 is offline
Old 03-08-2008, 11:18 AM
  #25
89mustangfive0
89mustangfive0's Avatar
well my pistons are flycut..and i would check ptv clearence any way....but i was upa t 230 last night and wrote down all the specs on some cams..and i found an edelbrock cam227/234 at .50 lift 520/520 112* looking in to it
89mustangfive0 is offline
Old 03-08-2008, 11:48 AM
  #26
silver91gt
silver91gt's Avatar
why not? the x cam will make more power than the b, and for $50 its a steal.
I know that everyone here votes for a "custom" cam, but $50 compared to like $500-600 is well worth it in my books.
silver91gt is offline
Old 03-08-2008, 11:55 AM
  #27
89mustangfive0
yea but the x cam is the same duration as the b but more lift..i was looking for something with more duration
Old 03-08-2008, 12:02 PM
  #28
OnyxCobra
OnyxCobra's Avatar
I'd broom the letter cam idea, go with a better grind. 302s love an exhuast biased camshaft.
OnyxCobra is offline
Old 03-08-2008, 12:21 PM
  #29
89mustangfive0
yea im liking the edelbrock cam...227 intake 234 exhaust and suppsoed to make nice power with the edlebrok performer heads im grabbin
Old 03-08-2008, 12:24 PM
  #30
OnyxCobra
OnyxCobra's Avatar
that is a very very agressive cam, what's the rest of your build going to be like?
Quick Reply: x cam ??
