x cam ??
Old 03-11-2008, 07:49 PM
  #51
bretdfords
bretdfords's Avatar
Default RE: x cam ??
There are alot of good points made my 2 cents are this, I've seen alot of different combos working at the dyno, and the best street RWHP350 was with a zcamin a stock bottom end 185AFR! 302 ci 650 rpm air gap.That little of difference between cams may not be worth the time and effort. I would Put your effort into the heads my suggestion that where the powers at, I've seen stuffwith very small cams that shouldn't makebig power belt it out with good heads.But I agree with jtmustang do what you want!
bretdfords is offline
Old 03-11-2008, 09:24 PM
  #52
94 5.0 fill
94 5.0 fill's Avatar
WouldI have to get my pistons flycut to put in an x cam with gt40 heads? What's the difference between the foxbodys and the 94-95s?
94 5.0 fill is offline
Old 03-11-2008, 10:35 PM
  #53
89mustangfive0
89mustangfive0's Avatar
i got a set of edelbrock performer 5.0s gonna put em on soon and thats why im looking for a cam probably anedelbrock cam#2221
89mustangfive0 is offline
Old 03-12-2008, 06:29 AM
  #54
Joel5.0
Joel5.0's Avatar
ORIGINAL: 94 5.0 fill
Most likely...... nope, but you need to check anyway. The main difference, and against the SN95 engine, are the hypereutectic pistons.
Joel5.0 is offline
Old 03-12-2008, 05:20 PM
  #55
94 5.0 fill
ORIGINAL: Joel5.0
What is the most safe way to check?
Old 03-12-2008, 08:36 PM
  #56
5spd GT
5spd GT's Avatar
ORIGINAL: silver91gt
ORIGINAL: 89mustangfive0
b303 224/224 at .50 lift 480/480 lift 112*
x303 224/224 at .50 lift 542/542 lift 112*
you arent looking at the total duration though, the valve events are different
http://www.fordracingparts.com/parts...rtKeyField=899
Not quite, they are the same.
Assuming you are talking about the lobe seperation angle, take this in...
5 + 5 = 10
7 + 3 = 10
The average of both is 5. Pretend that 5 is the LSA.
The LSA works the same way for both camshafts, because they have the same opening and closing events.
Intake Opening: 5* BTDC
Intake Closing: 39* ABDC
Exhaust Opening: 49* BBDC
Exhaust Closing: 5* BTDC
Take the intake side for simplicity, 5 + 39 = 44 degrees.
Add 180 degrees to represent the intake stroke (1/4 of a complete 4-stroke cycle) and you get:
180 + 44 = 224* (duration on the intake side).
Divide by two and you get the LSA - 112*. This works the same for both camshafts.
5spd GT is offline
GimpyHSHS
19
12-19-2023 01:12 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Quick Reply: x cam ??
