Crossmember rubber Mount
I found mine to be cracked and I need a new one. Anyone know of a good replacement for the rubber that connects the tranny to the crossmember. Should I also replace the rubber pieces where the c m goes to the under body of the car. Where can I buy these items for a good deal and again what should I buy. Thanks.
RE: Crossmember rubber Mount
You can get polyurethane motor, tranny mount kits from summit for like $160 or so.
http://store.summitracing.com/partde...p;autoview=sku
Crossmember bushings
http://www.latemodelrestoration.com/...1&comp=LRS
Is this the piece I need. Or is the something different about the one posted above?
http://store.summitracing.com/partde...530+4294925008
ORIGINAL: nitrous_bob
nope thats the trans mount, your good , same one i have.....but then the crossmember bushings are elsewhere....50 resto i think
Its the second link that I had sent you above.
ORIGINAL: projectresto83
