Need Help...
Old 03-07-2008, 09:35 PM
87Stallion
87Stallion's Avatar
Default Need Help...
Ok here's my issue. I have a 87 GT with 275/60/15's on 15x8 draglite wheels on the rear. On the passenger side rear the tire rubs the upper control arm and the tailpipe but not on the drivers side. I also noticed the spacing from the front and rear of the tire to the fender is much different on the RR. On the LR the spacing is equal. On the RR its not.
My question is could the rear end have shifted one way or the other??
Any ideas on how to remedy this issue besides getting a smaller tire.
87Stallion is offline
Old 03-07-2008, 09:53 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: Need Help...
yes but it won't be cheap!! I had simialar issue and here's what I did..bought 1/4 spacers from M/M...and then removed quad shocks and that helped rear rub probs but when cornering moderate rear rub still occured so I bought a MM panhard bar and locked rear to body and let me tell you this thing launches hard and straight and no rub whatsoever!!..here's final product:
http://i242.photobucket.com/albums/f...6/DSC00033.jpg
mjr46 is offline
Old 03-07-2008, 10:22 PM
87Stallion
87Stallion's Avatar
But what causes one side to be off that much??
Old 03-07-2008, 10:24 PM
87Stallion
87Stallion's Avatar
And what do you mean by expensive? How expensive?
Old 03-07-2008, 10:26 PM
87Stallion
87Stallion's Avatar
ANd damn your car is super clean underneath
Old 03-08-2008, 08:41 AM
mjr46
mjr46's Avatar
well ...you could take BIRTHA out and persuade the inner well in a little where it rubs......I installed longer studs in the axles with 1/4 inch spacers....= 20 dollars.....1/4 spacers from MM= 100.00........and pan hard bar from MM = 400.00 if I remember right..........as for differences side to side.. minw showed a little but not much.....I'd make sure there are no bent control arms or worn rear suspension bushungs allowing rear axle to shift a bit.....but I did all my mods in an effort to strengthen launch capabilities and correct rub...all in all it is rock solid for the power I throw to it and I'm well pleased with the handling capapbilities...and THANKS!!
mjr46 is offline
Old 03-08-2008, 10:02 AM
shawnk007
shawnk007's Avatar
I had had the same issue. I removed the quad shocks and installed stiffer upper and lower control arms. Now, it rarely rubs. Ive got to fly around a corner for it to rub now.
shawnk007 is offline
Old 03-08-2008, 10:37 AM
87Stallion
87Stallion's Avatar
Thanks, I'll give that a shot.
Gregz
10-18-2022 03:52 PM
mtdazeichael
06-01-2006 03:24 AM
naomi.t
06-01-2006 12:34 AM
John06GT
04-19-2006 01:41 AM
John06GT
04-19-2006 01:16 AM
Quick Reply: Need Help...
