t5 problems
RE: t5 problems
Putting fluid in a manual is a peice of cake with the right tools. Ever seen a fluid sucker? its like a grease gun housing with a pull/ push rod on it and a long rubber tube.. Stick the tube in ur tranny bottle suck it out and then put it in ur tranny and push the rod in on the sucking gun.. On a lift should only take 10mins to drain and refill tranny fluid..
RE: t5 problems
ok, 5th going in and out sounds to me like a piece of something in the way of the shift linkage for 5th
as for it only having 4th, he either totally ****ed his countershaft, or more likly broke the gear on his input shaft
either way that trans is trash, a rebuild kit isnt going to do **** for you, you need hard parts, and lots of them
no the 83trans is a non world class piece, and is ****, it wont last too long if he drive it like a mustang
just go to deperformance.com and spend 999 on a rebuilt stocker
Seanam
10-04-2015 10:15 AM
stangin1996gt
09-21-2015 11:01 AM
