T-5 Lube/fluid
Old 03-09-2008, 04:06 AM
O.C Stang
O.C Stang's Avatar
Default RE: T-5 Lube/fluid
Royal purple
O.C Stang is offline
Old 03-09-2008, 11:24 AM
5.0 85 GT
5.0 85 GT's Avatar
yea use royal purple..thats whats in my gt, i could feel the difference right off the bat, it made shifting a little easier...nice and smooth
5.0 85 GT is offline
Old 03-09-2008, 12:14 PM
1985stang
1985stang's Avatar
ORIGINAL: FASTBLACK
ORIGINAL: bighungrymatt
gm syncromesh
I know we use that in our TKO's but is that reccomened for the t-5 also?
http://www.astroperformance.com/prod...roducts_id/333
This says no, it is not supposed to be used in the T-5. I tried it because everyone on here said it was amazing, and it ended up screwing my synchros. 94gtcoupe told me it's because you have to flush the tranny with it first...so idk. I wouldn't risk it, it cost me $1000.
1985stang is offline
Old 03-09-2008, 01:11 PM
Tberg725
Tberg725's Avatar
When I had my WC T-5 built at a shop they recommended gm syncromesh so thats what I run.
Tberg725 is offline
Old 03-09-2008, 01:23 PM
AdderMk2
Banned
AdderMk2's Avatar
ORIGINAL: FASTBLACK
gm syncromesh
its not the "recommended" fuid... but it does a damn fine job
AdderMk2 is offline
Old 03-09-2008, 01:44 PM
ACE
ACE's Avatar
Im running syncromesh without a single problem through my 4 cyl t-5
ACE is offline
Old 03-09-2008, 04:40 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
How much fluid does the t5 hold?
I need to change the fluid in my wife's 98 v6 sometime soon and will I will be gettin Royal Purple.
projectresto83 is offline
Old 03-09-2008, 06:02 PM
86GreenMachine
86GreenMachine's Avatar
I use Redline.No complaints so far.
86GreenMachine is offline
Old 03-09-2008, 08:28 PM
mrshleepy76
mrshleepy76's Avatar
This may be a stupid question but I just purchased my 85 back in october and I haven't checked my fluid level. Were exactly is the the dip stick to add fluid being that its a manual I haven't found anything
mrshleepy76 is offline
Old 03-09-2008, 08:33 PM
WhiteWindsor
WhiteWindsor's Avatar
There is no dipstick for the manual tranny. There is two plugs on the tranny. One up top and one at the bottom. You take the top one off and fill till it starts seeping out. It would probably be a good idea to drain the fluid and replace with new. You drain it by removing the lower plug. You will have to get under the car to do this.
WhiteWindsor is offline
Quick Reply: T-5 Lube/fluid
