? about my supercharger
im farely new to blowers, i cant seem to get more than 5 ibs of boost , people are sayin to set it at 10 ibs of boost, how do u set a supercharger to what boost u want out of it???
RE: ? about my supercharger
well my car has an Strim vortech blower , with 75mm mass air and 70 mm throttle body with an SS1 bbk intake and also adjustable fuel regulator, and 190 bbk fuel pump, stock heads with a 306 cubic inch block, that the info u wanted?
no it is an s trim, the previous owner was runnin 12 ibs of boost, and yes im runnin the pulley it came with( bought used as a kit), and its cool it wasnt a stupid question
what size injectors you running? with that much boost, you need an injector that can handle the duty cycle. My opinion #30 at least i went #42 with a255lph, take away the FMU. what type of heads did the last owner have? Do you have black powder residue, belt slippen. Im sure u checked that though
You need to make sure all connections are nice and tight from the blower. You could be losing boost like a vacuum leak. Plus, you will not make maximum boost until you're at the motors maximum out put, e.i. you will not see 10psi at 4000 rpms.
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
