pvc value help please
RE: pvc value help please
ORIGINAL: warggod
where does the pvc hose run to from the value cover does it run in the back of my weind stealth manifold on the highest run or to the carb
ORIGINAL: warggod
i was told to run it to the manifold because then you get that oil vapor in your carb
what type of carb do you have? normally the pcv connection is right off the flange base on a carbed intake or if it's a hooley carb on the rear of the base venturie plate there is a pcv connection..generally you want to avoid tapping off a vaccum source for a specific runner on the intake as it'll lean that cylinder out.. you want it more at a central location to balance out the draw in of pcv vapors
do you guys no whats up with trying to buy value covers that will clears rollor rockers and get them with the holes already in them for carb motor i was wanting the square ford racing value covers but i think only one comes with a hole in it for the oil
