Something Annoying - Simple - need help
Old 03-11-2008, 01:36 AM
cholericfc
cholericfc's Avatar
Default Something Annoying - Simple - need help
The old return hose for my power steering pump is stuck, i can't remove it, in order to replace it.
1.) It has a clamp with a screw and I've loosened it all the way.
2.) I can turn/rotate it completely in 360 degrees.
3.) It won't come off - pulling on it, jiggling it, whatever.
Any TIPS?? i don't know what the hell to do....
cholericfc is offline
Old 03-11-2008, 01:37 AM
cholericfc
cholericfc's Avatar
Default RE: Something Annoying - Simple - need help
oh yeah, its really really dirty in that area, next to the radiator, its like its melted onto the metal hose....
Old 03-11-2008, 01:57 AM
AdderMk2
Banned
AdderMk2's Avatar
unscrew the clamp completely. it should open up and come right off.
once the clamp is off, slice the line with a razorblade...
AdderMk2 is offline
Old 03-11-2008, 02:06 AM
crusin92red5.0
crusin92red5.0's Avatar
i always have to stick a tiny flat head screw driver between the hose and what its connected to and try to break the seal all the way around. then pull and twist.
crusin92red5.0 is offline
Old 03-11-2008, 07:31 AM
cholericfc
cholericfc's Avatar
u guys are great...no room for the screw driver thing, but that is what i do.... thanks again
Old 03-11-2008, 07:06 PM
cholericfc
cholericfc's Avatar
it worked like a charm
Old 03-11-2008, 07:53 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
install a new return line while your at it..hose is probably old and dry rotted
mjr46 is offline
Thunderball
15
11-22-2015 11:49 PM
SSG Steggy
3.7L V6 Technical Discussions
11-05-2015 03:09 PM
flash_xx
10-16-2015 07:23 AM
tmdm
09-04-2015 06:45 PM
Quick Reply: Something Annoying - Simple - need help
