removing egr spacer from upper intakes?
I have a cobra upper intake. why is there no room, or why does it elimate the EGR spacer? part number 51 below. i would love to remove this, since my setup does not require it at all. i can get some well needed space for the airintake tube
RE: removing egr spacer from upper intakes?
i am almost positive that the cobra intake has a built in egr spacer, as you can see everything still hooks up, its just there is no gasket, and no extra piece to take off.
ORIGINAL: kweb288
ORIGINAL: djsprinklesnjo
Bypass the EGR coolant tubes with a bolt and clamp on each one, or if your good, customize them, to make it look like nothing happened.
Ford was in a Emmision's challenge with the 5.0 and thats why they did so much crazy stuff, to get it to pass Emissions and be able to keep the 302.
thanks for the answers, but stinks that i cant do anything about it, aode08, i cant do what you suggested bc like the previous members said, the cobra intake has it built in. there are no bolts to unbolt. see the pic with the yellow cirlce
TfcCDR
09-14-2015 12:08 PM
