403rwhp N/A EFI 345ci
Old 03-12-2008, 08:56 AM
jimt3te50
jimt3te50's Avatar
Default 403rwhp N/A EFI 345ci
I know it's not in a mustang and I apologise, but this is still windsor-applicable!
I am offering this feedback as I have used these forums as a tool for a couple of years now to see what works in the US for the humble 5.0L, and figured if someone got something from it, it would be worthwhile......
I had my car finally tuned after replacing the valve springs out recently to PAC beehives and this is the final result
http://i28.photobucket.com/albums/c2...126thFeb08.jpg
http://i28.photobucket.com/albums/c2.../DSC05191b.jpg
And the combination.....
AFR 185cc Alloy heads- 1492, 60cc chamber, modified pedestal mounts
Comp Cams XFI 5.0 Stroker hydraulic roller camshaft- 236/248 @ .050", 286/300 total, .579"/.579" lift
Yella Terra 1.6 ratio adjustable Aluminium Stud mount Roller Rockers
Full ARP Head, rocker and main studs
Full Felpro gasket set
Isky adjustable guideplates
Trend hardened chrom-moly pushrods
PAC 1235 Beehive springs and Comp lightweight retainers
Crane hydraulic lifters
ACL Race series rings and bearings
Rollmaster double row timing chain with nitrided gears
Stock T3 302W roller block- factory bored .020" oversize, torque plate honed (-.004" deck clearance)
Stock T3 ACL Hypeurtectic pistons, dished and notched (-9.7cc)
Stock T3 Argo shotpeened billet H beam rods
Stock T3 Tickford nodular iron stroker crankshaft
Stock T3 8 trumpet Intake manifold
Stock T3 82mm throttle body
Stock T3 laser cut main girdle
Stock T3 oil pump and sump
Walbro 255LPH fuel pump and std fuel rails and lines
Bosch 43Lb injectors
Difilippo 4 into 1 ceramic coated s/steel extractors, twin hi-flow 3" cats, twin 3" stainless steel all the way with X pipe, lukey Race mufflers and twin rear resonators
AU EEC SCT Edit- extensively tuned by Simon from Xtreme Ford Tuning
MSD DIS-4 ignition system
Xtreme Ceramic clutch
Herrod SureShifter
MSD Blaster 4 tower coil packs
MSD 8.5mm Super Conductor leads
Ford Lightning 90mm MAF
100mm intake assembly and shielded custom CAI with K&N filter
Optima D34 Yellow Top Deep cycle battery
The "stock T3" note refers to the stock components that were used in this Ford Australia built 5.0L stroker- by all accounts it ended up with soem pretty trick gear standard.
Anyway- just wanted to thank you guys for your input and see what you thought of the end result- notice the temps on the day are what you guys would call 100 degrees and is so much sharper on cold nights- sadly we haven't had a day under 35 since it was finished- it is awesome to drive though!
jimt3te50 is offline
Ipaman
09-22-2015 07:01 AM
jaiidutch
09-14-2015 10:29 AM
YoungStangsMan
09-05-2015 07:01 PM
1st 4 eyed fox
08-24-2015 06:56 PM
Jacob4589
08-08-2015 11:00 AM
Quick Reply: 403rwhp N/A EFI 345ci
