Car is hesitating and making popping noises
Old 03-13-2008, 03:22 PM
adaven16
adaven16's Avatar
Default RE: Car is hesitating and making popping noises
mine did this as well and after doing a complete tune up, and fixing blown head gaskets and nearly ever other gasket possible, mine still did the same hesitation and popping. granted i had a lot of things go wrong at once but in the end the hesitation came from my fuel pump going bad. i just finished replacing it yesterday and havent had a problem yet. just another suggestion. so i would definitely check the fuel pump.
adaven16 is offline
Old 03-13-2008, 04:26 PM
WhiteWindsor
WhiteWindsor's Avatar
ORIGINAL: Alero99
its SD no MAF
If you havn't already, try posting your problem in the SD/CARB/SSP section. You might get more help there.
WhiteWindsor is offline
Old 03-13-2008, 05:29 PM
88convertman
88convertman's Avatar
You know mine is doint the same and still doing it... Now why mine i think is doing it is because i just changed out my intake for stock OEM my old stocker was rotted in the back. I know aluminum cant rot... Who ever told you that is a F**king lier cus i have proof it can... any ways i changed everything out and put timing back where it was and it started doing it....Now when i took out the injectors i broke 1 pintle cap "nipple on the bottom of the injector" and replace that one with a new pintle cap from a 92 and it had a slightly different shape and slightly wider hole for spray. now i think the fuel in that cylinder is spraying differently then the others.... Maby to much gas in that 1 cylinder wich would cause a back fire threw theintake or tail pipe. I have the new caps coming this week. Ill post if it does or doesnt fix... If not im moving to fuel filter then pump after that its a new motor.
88convertman is offline
Old 03-15-2008, 01:30 AM
Forged331
Forged331's Avatar
Check your spark plugs. You can also check the wires at night by starting it in the dark and see if you see any arching. It does sound like fuel system....I'd lean toward the fuel pump...if your filter was dirty, you can bet the pump has seen some of that nastiness.
Forged331 is offline
Old 03-15-2008, 12:09 PM
Alero99
Alero99's Avatar
well for now if timing fixes it, it fixes it, fuel pump and regulator i have justt need a day to do em both (im a noob and i work slow) but if its just timing i can hold off on the other two
Alero99 is offline
Old 03-15-2008, 06:55 PM
Alero99
Alero99's Avatar
okay, did timing earlier, it was at rougly *15 and lowered it to *12
this does nto solve it the FPR and the Fuelpump and Strainer are next
Alero99 is offline
Old 03-17-2008, 12:03 AM
Alero99
Alero99's Avatar
Okay I did teh timing yesterday, i lowered it to rougly 12-13* timing...
did not drive the car till tonite and it is still doing it.
Before i Tackle the Fuel Pump any one have anything to add to this?
Alero99 is offline
Old 03-17-2008, 12:21 AM
ckyguy68
ckyguy68's Avatar
FUEL PUMP! Any bucking or popping would indicate a lean condition. Trust me, the fuel pumps love to go bad on these fox bodies. Grab a walbro pump and i bet that fixes your problem.
ckyguy68 is offline
Old 03-17-2008, 12:40 AM
Alero99
Alero99's Avatar
yay... now i just gotta find a couple hours and a helping hand to do this... and a few bucks to buy a new one haha
Alero99 is offline
Old 03-17-2008, 12:44 AM
89 5.0 Mustang
89 5.0 Mustang's Avatar
i had the wat seems to be the same problem on mine, mine did that and then wanted to die so try replacing the coil, fixed mine right away
89 5.0 Mustang is offline
Quick Reply: Car is hesitating and making popping noises
